First post, by cygnata
When I try to run the game using DOSBox, I get an error stating "A CD-ROM device driver is required to run Hand of Fate CD."
Appempting to use VDMS Sound will allow the intro to play, but once "Start a new game is chosen, it crashes with a fatal error. "The NTVDM CPU has encountered an illegal instruction."
Trying to run it in XP compatibility mode, of course, results in seriously FUBARed sounds. (Scratchy feedback type noises.) This occurs with both of my XP computers.
System specs: Laptop/Desktop
Brand: Gateway DS 4000/Frankenstien (homebuilt)
Motherboard: Unknown, see brand/MSI, model forgotten
Processor: 2.5GHz P4/2.4GHz P4
RAM: 256MB, type unknown/256MB DDR
Video: Unknown/GeForce 4 MMX, 64 MB video RAM
Sound: Allergro chip/Soundblaster Live! with legacy drivers
OS: Windows XP Home/Windows XP Pro
Sound mode: default
Video mode: Software
Resolution: 1024x768/1024x768
VDMS version: 2.1.0
DOSBox: 0.58
Reply 1 of 3, by avatar_58
First of all your dosbox is way outdated....use 0.63 and see if it helps. Second, have you mounted the CD-ROM drive first?
Reply 2 of 3, by cygnata
Honestly, I didn't check the version, since I only redownloaded it yesterday. I used the number in the forum posting rules. The rest is verified where possible. I am aware this probably loses me a few respect points. ^^;;
And yes, on the desktop I actually mounted both of the DVD drives on there, and on the laptop, it's sole drive.
Reply 3 of 3, by HunterZ
Man we need to fix all these references to old versions that are floating around...
