Fast DOSbOX?
First post, by Patrick
http://sourceforge.net/projects/fastdosbox
What exactly is this and how do I get it to work? Plain DOSBox runs pretty badly on my system..
Reply 2 of 7, by eL_PuSHeR
What is that? A Real Time Clock patched version?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
no some code optimalisations
Some make sense.
but some don't (no offense)
The coder changed a lot of multiplies into bitshifts (good thing)
but also precalculated certain values. (like 8*1024)
That isn't needed. I tested the following:
#include <iostream>
int main(int argc,char* arv[]) {
std::cout << 144 << std::endl;
return 0;
Which gave exactly the same results as:
#include <iostream>
std::cout << 12*12 << std::endl;
return 0;
the resulting execatables were the same. Maybe this isn't true when used in calculations.
The author frequently changed:
if (y&1) off+=8*1024;
to
if (y&1) off+=8192;
I doubt that makes any difference
However most of the bitshifts might work.
Futher the author implemented a jumptable FPU core.
Might be good. but it was based on 0.63 source and the current source is lot different
He might have done more things. but these were the things I noticed. while quickly browsing the source.
Those bitshits in in the main cpu loop might be a good thing to do.
Water flows down the stream
Reply 4 of 7, by gulikoza
Creating a seperate project seems somewhat unnecessary since the effort could be spent on improving official code. Also, current compilers make such code changes unnecessary as well - a simple line a = a * 1024 will compile into SAL 10 so compiler will optimize multiplications into bitshifts when possible (unless of course the compiler cannot see when to optimize but a good programmer can).
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
> Futher the author implemented a jumptable FPU core. Might be good.
...but it won't be any faster as the fpu operations are very
heavy themselves.
Reply 6 of 7, by HunterZ
Still, every bit of optimization helps as long as it doesn't adversely affect the maintainability, stability, or portability of the code.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
None of those optimizations can't be done by the compiler
(msvc already uses jump tables for the fpu, i assume gcc
does that as well), except for the optimized idle looping 😉
And replacing constant calculations by precalculated values
DOES affect readability.
