First post, by Elia1995
- Oldbie
Hi, yesterday I managed to get a PCI Realtek RTL8139 network card to work in Windows 98, I can connect to Internet and "almost" browse (well, with a loadful of SSL certificates errors every second on Netscape and IE), but I can't access the local network, I can't see the shared folders on my Windows 10 PC and I can't share anything in Windows 98 itself, obviously I enabled both files and printer sharing in the network configuration under Windows 98, but when I right click C:\ to share it, it just isn't there, it should be right there in the contextual menu, but isn't.
When I open "Neighborhood Nework" or however it's called in English (it's "Network Resources" in the Italian version of Windows 98), I only see "The whole network", but when I double click it, I get an error which says it can't access it.
On the login screen when Windows starts, now I see Username, password and DOMAIN, I have no idea what that Domain field is for, but if I leave it blank, it doesn't let me log in with my user name and if I use either WORKGROUP or HOMEGROUP as "domain" it says those domains don't exist or something like that and local networking would be limited, so I can access on Windows 98 only if I press cancel at that screen.
As I said at the beginning, Internet itself works fine, but how do I set up local network and get it to share on workgroup along other local computers ? I can't find any useful information on Google and, as usual, Vogons is my last hope, if you guys can figure out what's going on in that Windows 98 PC.
Screenshots coming up, if you need.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
