First post, by Aglenoth
Hello, i have recently found this 486 desktop Elonex WS-425SX but I can't install any software , I have tried to install dos on another computer, however when i put it back , and set disc donfiguration (it's Toshiba MK1724fcv hdd) , and when i try to boot it Outputs this :
Starting MS-DOS
Starting MS-DOS
__
And then it hangs, no beeps , nothing.
Any help is higly apriciated 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 2 of 11, by dionb
DOS is pretty basic and boots off BIOS routines, so if your DOS install works on one PC compatible computer, it should do so on another.
If not, you've got hardware problems. Given that you get 'Starting MS-DOS' the HDD seems to be recognized and at least some data (the boot sector) is being read. Possibly your HDD is too large for the BIOS, but I'd be surprised if 362MB would be too large for anything.
Other suspects: that Elonex WS-425SX would have shipped with a 486SX-25, yet your photograph shows a 486DX2-66. Possibly some component (low-spec RAM or cache) doesn't like the 33MHz system speed that uses. Try underclocking to 50MHz (25MHz bus speed) and see what happens then...
Reply 3 of 11, by dosgamer
Easiest is to use a CompactFlash card and mount it as a disk in VirtualBox on any PC and install away. Second easiest is to use an IDE-USB adapter and do the same thing.
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
Reply 4 of 11, by Aglenoth
I have talked to the guy who sold me this unit, It's WS-450 but with different front panel , soo i apologize, and the rest inside is from WS-450 as well , even the hdd was included there originally , I don't know where is the problem 😒
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 5 of 11, by Aglenoth
I love to keep system original, I could get my hands on adapter, but since i have second system that i use for file transfer, there is no extra need of using one 😀 I guess it's hardware fault then 😒
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 6 of 11, by PCBONEZ
Check the power voltages.
Reply 7 of 11, by Aglenoth
Everything is correct, i have checked the PSU and even replaced it several times
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 9 of 11, by PCBONEZ
Will it BOOT a floppy with no HDD connected?
The HDD may have a corrupt MBR.
Reply 10 of 11, by Aglenoth
It uses proprietary floppy drive that i dont have , the disk booted on second PC
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 11 of 11, by PCBONEZ
Bearing in mind I'm going by a photograph....
That looks like a standard 34-p floppy header.
I suspect the only thing proprietary about the original FDD is the mounting and electrically it's standard.
A standard FDD should work for trouble-shooting, you just won't be able to install it in the case.
