MKT_Gundam wrote:I made a mistake. The Aztech card is a 2320.
Looks like this pic:
https://preview.ibb.co/cMOWW7/2230.jpg […]
![2230.jpg](https://preview.ibb.co/cMOWW7/2230.jpg)
The Aztech chip is a 2320.
For the card, look for the FCC ID (I38-xxxxxxx). If it's this one, it's a slightly older one than the I38-MMSN855 I mentioned - but in terms of sound compatibility/features it's just the AZT2320 that's relevant so that will be the same, only the output quality may be different. So in any event, as good as ISA PnP is going to get, and full hw SBPro2 compatibility with real OPL3. Just a 28k8 or 14k4 modem instead of 56k6 😜
In any other case I'd recommend it, but with an Audician 32 and an SB32 with RAM making it a full AWE32 as alternatives you are spoiled for choice. Only reason the Aztech might be a better choice is if you get resource issues with those two due to ISA PnP and/or resource reservation hell - I have at least one system where the AZT2320 is the only ISA sound card I can get to work...
