First post, by smichelsen
I have an '80s DOS program that can create and save small files, and also load them for use later.
Within DOSBOX I am able to save a file to the mounted "A" drive (a folder on my c: drive).
However, when I attempt use the pgm to load the file back in, I get a disk error.
What could be the cause here?
I have read that doxbox is not for games, but so far this emulator has worked better than the others I have tried (vdos, vdosplus).
Anyone care to suggest an emulator? I would like to avoid using a full dos app inside an emulator!
Thanks,
Steve
