First post, by toonit
Hi there, new to the site. I'm looking for some help to get an old Compaq that we had sitting around in the back at work running on a larger HDD.
The system originally came with a 2GB disk, but I'm trying to get it running with both a 40GB and 8GB (model number wd80eb-28cgh2, out of an original Xbox) drive (not at the same time, tried with both). The setup floppy seems to read and detect the disk, but when I try to run the setup for Win98SE it thinks i have no drives installed. Trying to format either drive in fdisk throw an "Error reading fixed disk" message but I know that both drives work just fine.
I have also upgraded the bios to the April 98 and that doesn't seem to fix the issue. I'm new to working on a system this old so its quite possible I overlooked something. Any suggestions would be greatly appreciated.
