Full screen problems
First post, by XSmoke
When I switch to full screen, monitor turns off. It's not funny. Nothing helps. Helpme! 😕
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
blame your monitor.
try looking at the refresh rates your monitor supports. See if you can set it high enough. (at least higher then 60 hz)
Water flows down the stream
