First post, by kiddcabbage
Hello,
I am trying to play the System Shock XMI files through a Sound Blaster Pro 2, but I am having many problems getting the files to play correctly through any OPL chip.
I have all of the XMI files from System Shock, as well as cit.opl. I have tried using xplay from AIL2, as well as the MIDIPAK tool and I'm getting the same results - only percussion is playing! The XMI files play fine through GM, but any playback through an OPL is just leaving out most of the audio layers.
Every other XMI file I have tried has played back fine with any OPL file. System Shock's will not play correctly with any OPL file, including its own. It only sound correct with GM (which for my intentions will not work).
I will admit I am doing all of this in DOSBOX, and using its soundblaster emulations, but considering every other XMI file is working properly, I don't think this should be an issue.
I know less about OPL synths than I do GM; I'm not exactly sure how the .OPL file is routing the XMI tracks to each channel, nor why I should be having problems with this in this case. Any ideas as to why I'm only hearing percussion play back from any of System Shock's XMI files on OPL?
