First post, by candle_86
- l33t
So Got a good deal on the fleabay and bought an IBM Aptivia Slot A board with Athlon 700, waiting on it to get here, but I've heard AMD Irongate has issues, which issues should i look out for you think
Sketchy USB. I just could not get it working on my Gigabyte board.
My builds!
The Underdog - The budget K6
My Irongate has been very reliable, my most reliable PC in fact (especially as I bought it for £15 from someone who claimed to have just found it in their attic). I haven't found any specific chipset drivers as such. I install USB from here, and then just "AGP slot" drivers (if using AGP) and "IDE drivers". My board is this MSI MS-6191. It is a RAM Slut and doesn't care what RAM goes in there, mix and match speeds, brands.
I've not had one issue that can be attributed to the chipset EXCEPT for it not supporting Thunderbird Slot A CPUs when the bios and chipset say it should... I've got a 800MHz first-gen athlon (forgot what they're called). I'm not a power user though, like, I haven't tried putting a 5950 Ultra or anything in there, so I don't know how well it goes when really pushed.
alright well i look forward to seeing how i like it, my cpuid string id's it as a Pluto core 700mhz
AGP 2x 3.3v, but may be limited to 1x.
The later version, supporting super bypass, was better
https://www.tomshardware.com/reviews/amd,155.html
What graphics card you using, People trying to install their new and expensive graphics card caused the most problems back then.
Now that AGP is mature and dead its much easier picking the working combinations.
(its why Voodoo's were popular back then as really they are bridged PCI cards)
Well I wont be doing this, the fleabay seller accidently listed it for sale, he claims now he didn't have one to sell at all
I have instead grabbed a K7M
I've just realised my board has Super Bypass and it has been disabled all this time! I might do some benchmarks with and without on my 4x Mx440 to see if it makes a big difference.
well ill be putting my voodoo 3 in this, move my GF3 to my P3, and put my Geforce 6600 256mb into my XP 2500
The AGP is a little flaky on AMD 750. Voodoo cards work fine of course. So does TNT. But the GeForce cards are another story and IIRC the NV driver forces them to AGP 1x. It's similar to what you see with Super 7 boards. AGP quirks are the only problem I've seen with K7M.
so using the voodoo 3 ill be fine, awesome. Oh I intend to use a live, does the 686A southbridge have the data corruption issue or just 686B paired with live
