First post, by LLugnuto779
I had a good idea, but i am not sure of how well it would work, or if it would work at all
Pentium 3 xeons supposedly have unlocked multpliers, and slot 2 motherboards are very hard to find.
I wondered if it was possible to mod them (or make a right angle adapter card) for slot 1.
As far as i know, nobody has ever actually tried this. (probably because nobody cares, but i don't know)
Reply 1 of 6, by The Serpent Rider
Nearly impossible to mod due to difference in size, notches, slot pins, etc. Probably possible to design custom adapter, but that would require BIOS rewrite too. So good luck with that. Also it won't fit in any ATX case.
Reply 2 of 6, by SSTV2
Never had those CPUs and never bothered to research if that's possible, but if PIII Xeon architecture is the same as of PII/PIII then it should be possible. Compare "pin-out" of both Xeon PIII and Coppermine PIII Slot1, if signal descriptions match - it can be converted directly, if not, some additional mods should be done.
BIOS mod shouldn't be a problem at all, you'd have to inject a 2 to 4 KB CPU uCode with hex editor and that's it.
Reply 3 of 6, by danijelm
I was thinking about this before some time, but i find some problems in pinout mismatch. Here's table with signals slot1 and slot2. Maybe someone have idea is this possible.
I speak sarcasm as a 2nd language
Reply 4 of 6, by nforce4max
Making a slot interposer is likely to be the easy part however Slot 2 Xeons often need two discrete VRMs, one to power the cpu core itself and the other to power the external cache for those that have it.
Reply 5 of 6, by Errius
The Netserver LH4 has 4 CPUs but 6 VRMs
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 6 of 6, by RaverX
I think it can be done, slot 2 xeons are basically nothing more than PIIs or PIIIs with extra cache (some are even with the same amount of cache). It seems that slot 1 to slot 2 adapters exists:
https://www.anandtech.com/show/318
Slot 2 to slot 1 could be done, power requirement might be a problem, as nforce4max said, but they could also be solved by attaching a molex connector to the adapter and converting 5 and or 12 V to the required voltage for the cache.
However, the fact that such an adapter doesn't seem to exist might indicate that there might be some other problems. Or there would be too expensive. Or there wouldn't be a demand for such product. Back then (in 98-99) a Xeon CPU was very expensive, and it was used in servers in dual/quad configurations. Pairing such an expensive CPU with a mainstream single slot 1 board didn't made sense back then. But now it would be fun to try.
