First post, by Jupi
I have to say I am not happy about the way the conf file is hidden away in windows on the recent versions of dosbox. This is just awful because I have to search for this thing every time I edit something and it takes forever. And the conf file I edit through the menu is not the right one somehow.
That out of the way, I am trying to make a batch file for each game to make them run properly instead of fiddling with this thing all the time.
This is the one for sim city 2000
mixer master 10
cycles = 7000
windowresolution=1600x1200
sc2000
Everything works but the resolution. Is there some way to make the resolution change once the window is started?!
If not is there a way to source a separate conf file for each game? I don't want to use an front end to dosbox though.
