Hey quicknick! 😁
Upon closer inspection (the previous pic was from the seller), it clearly says 32kx8 on the board, in two banks. The jumpers are also labelled very well. I really like the attention to detail in this machine! All the cache sockets are 28 pin, but the TAG chip is a 32 pin SOJ.
I think I'll get the 32kx8 units off eBay, but I'm not sure about the tag. Now that I have a spec sheet for the product number, I will take a multimeter to the TAG socket and see what/where the voltage comes out of, and compare it to the spec sheet.
So far so good, I transplanted all the goodies out of my clone 486/66 (hard disk, CDROM, NIC, sound, video, and CF, as well as replaced the BIOS battery). I also paired it with my NCR 17 inch CRT which is looking a bit worn, in need of a power button cover, and generally some retrobrighting.
Here it is:
It's pretty tightly packed in there, but I appreciate the German 90s build quality.
What I still need to do:
-CACHE!
-5.25 inch floppy
-CPU fan
-Solder on a small 3.5 inch floppy power connector for my CF card reader
-Obtain a Microsoft PS/2 mouse
-Load DOS/Win LAN drivers
A fall/winter project for sure.
What's for sale? my eBay!
