First post, by snorg
Lots of parallel port devices/drives have a pass-through port so that you can use the drive with another parallel port device.
Which makes me wonder, is there a limit on how many you can daisy-chain this way? I know with SCSI you could do seven devices but SCSI was designed for that, the parallel port (as far as I know) was only ever meant for printers and was adapted for other uses. So I imagine you could do at least 2 but I would be curious what the limit is. Anyone out there have several LPT devices hooked up like this?
Reply 1 of 4, by derSammler
There is no limit, since daisy-chaining was never intended. The port is designed for a single device. Daisy-chaining works until the voltage drops below the point where the other side can no longer distinguish between TTL high and low.
Reply 2 of 4, by snorg
Ok, so there is no set limit as such, but would it be fair to say a practical limit is maybe 2 or 3 devices?
Reply 3 of 4, by ibmapc
I think you would be limited by the types of devices chained together as well. You would not be able to use more than one of a particular device type. I.E. you won't be able to chain two Parallel Zip drives or anything that uses the same resources.
Greg.
Reply 4 of 4, by Zup
I think that the limit is TWO devices, and one of them must be a printer.
I've only seen passthrough ports in external drives and scanners, but I don't think that you can chain two of those bidirectional devices.
I'm selling some stuff!
