First post, by drakonfire
i'm a linux user, specifically gentoo... so after emerging the program, and getting the tyrian2k game files i needed, i launch dosbox, happy to be able to play my favorite all time shooter
problem, the default cycles are at 3000, tyrian requires at least 8k to run without slowdown, my computer can handle that, but i have no way to change the cycles! ctrl-f8 does not work, and i have no idea where to place a config file, i have tried using a front-end, dboxfe, but the starting cycles on that only go up to 3500, which is still well shy of what i need, how do i get my cycles up?
Reply 1 of 3, by DosFreak
CTRL F11/F12 change processor cycles
CTRL F7/F8 change frameskip
dosbox -conf configfile
to load a specific config file....
Reading the README might help you......as a linux user you should know this.
Can't help ya with frontends.
Make your games work offline
Reply 2 of 3, by drakonfire
late reply, i know, thank you very much
the readme was/is hiding and i can't find it, though i haven't had a whole lot of time, college = butt kicking 😜 anywhat, now i can play my fav shooter of all time, thank you again
Reply 3 of 3, by `Moe`
The readme is where all docs are on gentoo: /usr/share/docs/dosbox-<version>/README.gz
