First post, by Fimbulvetr
Lately I've been using an old computer (P133, Gigabyte GA-586HX) that I built new back in university as my retro dos computer. I pulled it out of my parent's basement earlier this year, and while it worked fine, the case was a yellowed, beaten-up, rusty mess. So I recently acquired a very nice new-in-box AT tower case, complete with power supply and a 3-digit turbo display for $20 and proceeded to move the gubbins from the cruddy old case to the shiny new one. I turned it on, and it started up and ran fine except for one major problem.... the keyboard doesn't work. The computer recognises that there is a keyboard attached as I don't get any post errors. The keyboard lights work. If I press the num lock the keyboard light turns on and off. But the computer does not acknowledge any key presses. I can't even press DEL to enter the bios. I've tried several different keyboards with the same result, and I've tried removing everything possible, re-seating the memory, etc. I can't see any obvious problems with the thing.
Before I dismantle the whole thing and start going over the motherboard with a magnifying glass and a soldering iron (I was thinking of re-soldering the keyboard port), I figured I would ask if anyone can think of any stupid obvious things I may have overlooked. Any ideas?
Reply 1 of 3, by oeuvre
try removing the mobo from the case and do a barebones keyboard + video boot, see if it works out of the case... it will let you know if the case is shorting something or if the issue is on the mobo
Reply 2 of 3, by Fimbulvetr
Oh jeeze. It just occurred to me that my new case has a keylock that I had to wire it up because the power LED connector and keylock connectors were attached. The old case didn't have a keylock.
I never checked to see if the case keylock was on or off.
Reply 3 of 3, by Fimbulvetr
Yup. It was they keylock. Something stupid and obvious that I overlooked.
