Tomb Raider 3 broken
General information and assistance with dgVoodoo.
Postby b_m_l » 2018-4-02 @ 13:21
Tomb Raider 3 + dgVoodo (+Reshade) = everything white Oo any suggestions?
b_m_l
Re: Tomb Raider 3 broken
Postby Dege » 2018-4-05 @ 18:10
Weird... TR3 works for me.
1. Try to launch TR3 with the -setup option (TR3.exe -setup) to reconfigure your graphics settings.
2. If it still doesn't work then could you plz post me a debug-log using the spec-release version of dgVoodoo?
Dege
Postby Nucleoprotein » 2018-4-24 @ 05:24
Not broken at all - you enabled 8bit textures in configuration and dgVoodoo is not supporting them properly - so no textures at all. Use ATI card in Control Panel, it disables 8bit texture support and game will not enable them at all.
Nucleoprotein
Postby Dege » 2018-4-24 @ 19:13
Indeed... 8 bit textures. Now I remember I was investigating that some time ago but as far as I remember I didn't found problem on dgVoodoo side. :S
Dege
Postby sevirus » 2018-10-04 @ 18:53
hi folks
i got the same problem, but 8 bit is turned off. if i turn 8bit on the texturs are black.. what do i miss?
sevirus
Postby Dege » 2018-10-06 @ 19:49
Hi!
Could you plz post a screenshot of your TR3 graphics settings dialog?
Dege
Postby sevirus » 2018-10-07 @ 07:38
i changed die card to an ati but that didn`t help.
sevirus
Return to dgVoodoo General
Who is online
