First post, by MTD
Hello,
When i am running DOSBox 0.74 on Windows 10 the Windows screensaver / standby timeout will be blocked. Is there any possibility to disable this future?
For Linux i found the solution by setting the environment variable SDL_VIDEO_ALLOW_SCREENSAVER. Is there a same solution for Windows?
