First post, by GabrielKnight123
I have a Pentium 200MHz with MMX for a socket 7 motherboard and the original fan is 50mm but I cant find any Noctua or similar in the 50mm range so I have a 40mm Noctua NF-A4x10 FLX fan that I am not using the yellow wire so its running at 12 volt all the time but the 40mm fan doesn't quite fill the heat sink all the way would this fan be good enough?
