First post, by matze79
- l33t
i made a little Adapter allowing connection of a microsd card to the lpt printer port.
due do the fact chinese microsd modules with levelshifter are cheaper then a single mmc slot, i used a ready made module 😀
simple single sided PCB.
For Homemakers:
i used this Adapter:
https://www.ebay.de/itm/5Pcs-microSD-TF-Card- … 872.m2749.l2649
Note that this is not very fast, around floppy drive speed, depending on cpu speed.
And here is Nilquaders Driver, its most stable one i found.
There is also SPPD 1.1 Driver which runs also with some SDHC. i need to swap two Pin's in Code so both drivers can be used.
Swapping MicroSD is not possible without powercycle.
Thanks
Matthias
