First post, by paulo_becas
I've been trying this for a while and can't get it to work.
Does anyone ever manage to get cannon fodder to work on your DOS PC with the MT32?
It crashes the computer every time.
AMD Am486/Am5x86-P75 DX5 133 Mhz-64Mb Ram
S3 Trio 64V2DX 2 Mb
Soundblaster AWE64 Gold+Music Quest+MT-32+MU80
LAN-3Com
1.44 3,5 Epson Drive+1.2 5,25 Mitsumi drive+Iomega Zip 256Mb
8gb HDD,4Gb CF HDD
HP CDRW 9200
http://jp-retro.blogspot.com
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The MT-32 music in Cannon Fodder does not work in DOSBox when cycles are too high; e.g. the music works at 8000 cycles but not at 10000 cycles. So, on a real system you may need to slow things down: turn off turbo mode (if applicable), disable CPU cache, use slowdown utilities, etc.
Reply 2 of 3, by paulo_becas
If i slow down the computer will the game still works well or does it slow down too?
S3 Trio 64V2DX 2 Mb
LAN-3Com
8gb HDD,4Gb CF HDD
HP CDRW 9200
Reply 3 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Minimum processor requirement for Cannon Fodder is 20 MHz 386SX, so just be careful not to go below that level of speed.
