First post, by walterg74
Hi folks, I recently came across this 486 board.
I haven’t gotten to test it out yet (I got it today), but I’m trying to identify it as it seems to have come from a brand name machine.
It has a 486SX-33 processor and a lot of onboard goodies like IDE, floppy, S3 VGA, and PS/2 ports. It also doesn’t have a regular battery but one of those Dallas thingies...
I would like to identify it first to see if I can get the proper drivers for it, and also to see if I can find the proper riser card for it, since it didn’t come with one and I can’t add anything else to it otherwise (I would like to at least add sound).
Thanks for your help!
Reply 1 of 4, by Predator99
See label - Unisys. Without case and riser card rather useless.
Reply 2 of 4, by walterg74
Why would I care about the case...?
How can it be “useless” even wothout the riser card? Save sound I have everything I need...
Reply 3 of 4, by dionb
Morover this is a regular LPX board, so should fit in pretty much any LPX case. The riser is more specific, but usually can be found on well-known auction sites.
Reply 4 of 4, by evasive
In this posting someone is using it without the riser card
Help with Am5x86 performance issues
Basically EVERYTHING is onboard.
