First post, by trekmann1
Hi, This is a bit of an odd question.
I run Dosbox 74 in Linux (Fedora) not the new 74-2. I have two old BBS games that are registered. The program looks for a specific reg file. In one of the games no problem. The other game says the game isn't registered.
However if I run that same game in a Windows Doxbox, then it does see the reg file fine.
I'm not sure if there is anything I can check.. my Dos games are stored in my home folder, and accessed that way I've checked file permissions, I thought perhaps the game is down in too many subfolders (I've found a game or two that had that issue), but for this BBS game I get the same problem on the Linux version. But Windows version of Dosbox no problem
Any suggestions would be welcomed.
Thanks
Reply 1 of 2, by Asterisk
Is the directory containing the registration file mounting correctly under Linux? Remember that the path delimiter in Linux is a forward slash (/) instead of a backslash, and that file and directory names are case sensitive. If you're using the same mount command on both OSes, confirm that the path you're mounting is actually valid in Linux.
Reply 2 of 2, by lightmaster
Yeh it 'looks' like a path problem..
