First post, by newold86
Slowly moving forward to my bigger project, found a need to do more experimenting. Something was done because of the need, something - just for fun, but at the end I made a more sound-oriented version of my universal (almost) 8-bit card:
1. Relatively large FPGA, that allows to do almost everything imaginable
2. A lot (for 8-bit system) of DRAM - could be used as EMS, video-RAM etc
3. A lot of flash memory - could be used for something 😀
4. RTC
5. HDMI connector - virtually any videocard can be created in FPGA, and will be quite handy to use HDMI to connect it to modern monitors
6. RCA connector with the circuit from original CGA adapter - still trying to re-create cycle-accurate CGA, but don't have enough time for now...
7. microSD card connector - to use SD card as HDD
8. More-less decent audio CODEC
9. Real OPL3 chip
10. Connector for waveblaster daughter card
11. External MIDI interface - planning to adapt HardMPU
Reply 1 of 14, by Pantheon
Oh my god! I would love to play with this thing!
I was planning to make something similar but with one of the old MAX 7000 series CPLD devices.
This looks seriously impressive.
Also... how do you assembly those teeny little SMD parts? Do you do it yourself using something like reflow?
Reply 2 of 14, by newold86
Unfortunately, MAX7000 or similar is very limited - good for things like an address decoder, data latches etc only. With "real" FPGA you can do A LOT of different things that impossible with basic CPLD...
Actually, not really difficult after you got some experience and have proper tools. Whole thing (from empty PCB to working device) took around 1 hr. Use stencil to apply some solder paste, place parts using manual placer and put the PCB into reflow oven. Repeat for the top side 😀
Because of space limitations, had to use 0402 bypass capacitors for FPGA on the bottom side:
Reply 3 of 14, by root42
Ok, so you have a stencil and an oven... we can surely expect a bunch of those cards soon for us to buy? 😀
YouTube and Bonus
Reply 4 of 14, by newold86
Sorry - it's just a hobby... And I have not tried to make a finished product - it's more about playing with a technology for test purposes...
If someone really interested to make them, I provide (of course, for free) all design files. But you have to be realistic - it's not cheap (8 layers PCB with relatively small clearances, FPGA chip etc) and not for someone without previous experience with BGA packages...
Reply 5 of 14, by Tiido
This is pretty cool !
I don't see a transmitter chip for HDMI, I suppose it relies on bitbanged TMDS ? Max10 IO aren't terribly fast, I wonder what is the max resolution one can reach. Ideally one would output panel native resolution to avoid latency and bad scaling that most monitors seem to have with low res content but 1920x1080 will be unreachable without Gbit transceivers.
Reply 6 of 14, by newold86
Theoretically, it's possible to go up to 80 MHz pixelclock using DDIO in MAX10. Practically I'm struggling right now with HDMI 🙁
Reply 7 of 14, by Tiido
80MHz is really low, I'm doing several hundred MHz IO on a Max10 and specs suggest 300ish MHz is no problem. True LVDS transmitter pins should be able to reach 700MHz which should be enough for medium resolutions, I'm not sure if you wired any of those to HDMI or not.
Reply 8 of 14, by newold86
80MHz pixel clock - it’s 800MHz on the transmitters...
And yes - I used LVDS pins...
Reply 9 of 14, by Tiido
Right, now it makes sense. 8b/10b coming into play too. 800MHz is at the maximum for the chip...
IT6613 would be a choice for the transmitter chip, it is used by Open Source Scan Converter project. Register documentation I haven't been able to find but the source code would be a starting point to get good default values going.
Reply 10 of 14, by Jo22
Wow, this is really cool! 😁
Please don't forget to add 640x400 CGA mode of the Olivetti M24 machines, quite some Turbo Pascal programs could use it (there was a bgi file for it). 😀
Reply 11 of 14, by appiah4
That is all.
Reply 12 of 14, by newold86
appiah4 wrote:
https://media.giphy.com/media/yAYZnhvY3fflS/giphy.gif […]
That is all.
As I have explained already, for a number of reasons I don't make my projects for sale. If someone decides to produce and sell any of my projects, I give away all existing info for free and without any significant conditions.
Reply 13 of 14, by appiah4
You are such a killjoy... 😒
Reply 14 of 14, by newold86
Sorry 😀
If someone has skills and desire to develop IP cores/firmware for my projects, I can consider giving away a working card to that person.
