Ultimate multiboot - Old+New (DOS+W98,Xp,7,10+Linux,MacOS,Android-x86) on newest HW research - compatibility matrix
Showcase your Retro PC / Build logs.
Re: Ultimate multiboot - Old+New (DOS+W98,Xp,7,10+Linux and MacOS) on new Hardware research results - compatibility matrix..
Postby ruthan » 2018-11-23 @ 09:37
So far we did not break PCI-e sound card barrier in DOS (with Win98+ its working fine), but i just for fun tried PCI videocard (ATI MACH 64VT2 1 MB) in PCI-E to PCI bridge (Asmedia chipset pci-e to 2x pci - i probably have unupdated version) and Gigabyte X58 MB and its working..
So you can safe / multiply precious PCI slots, or at least have possibility to choose between pci and pci-e slot for video card.. of course there is cable / space hassle.. because you need microatx mb in ATX case, to use not use case card slots.. or if are using standard ATX mb, you need big case with 8+ card slots.. or need to have bridge outside of case (some nice box like for external gpus could be made, from case its just USB cable), or inside in case and vga cable inside too..
I created special thread for PCIe-PCI, PCI-ISA slots back plates, bridges, multipliers etc..:
here
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough HW.
User avatar
ruthan
Location: Schwarz Wald-from France to Ukraine, from Denmark to Austria. Celts+German+Slavs melting pot.
Postby ruthan » 2018-12-06 @ 21:59
User avatar
ruthan
Postby Doomn00b » 2019-2-23 @ 16:37
I'd just like to say... this thread, and the work Ruthan has put down in researching and testing these things, are BEYOND epic! : O I had the same kind of mad, mad idea recently, but I had but begun to look into things, when I found Ruthan's info-resources.
Stellar stuff, dude! Keep doing the good work!
User avatar
Doomn00b
Re: Ultimate multiboot - Old+New (DOS+W98,Xp,7,10+Linux,MacOS,Android-x86) on newest HW research - compatibility matrix
Postby ruthan » 2019-2-23 @ 18:25
Look here its my main thread"
viewtopic.php?f=61&t=61044
User avatar
ruthan
Postby ruthan » 2019-3-05 @ 00:12
In last days i was experimenting with Z170 MB, here are some issues which i have to solve, i can have some half defective MB, but is not probable:
https://docs.zoho.com/sheet/published.d ... 550e802f86
Used HW:
- MB - GA-Z170-HD3 - https://www.gigabyte.com/Motherboard/GA ... -rev-10#ov
- CPU Intel G4400 cheapest CPU which i was able to get for testing (Ultra slimer, i hope that is not missing some needed instructions)
- GPU - KalmX 730 GT 4 GB (DDR 5), i had not problem with it with other machines, some errors are there even if videocard is not under load..
- HDD - Seagate 500 GB - Aida / HWinfo report SMART values as fine, worked with other MB, i not for long time and no some long testing, but all seems to be fine.
- Aureal Vortex 1 PCI sound card - tested with other machines
- Silicon Image 680 PCI controller - but problem were appear even before i added it to system, and other controllers
- Asmedia Sata 106x controller in IDE mode - - but problem were appear even before i added it to system, and other controllers
- Geforce 6200 TurboCache, used only for Win98 and Dos - at least Memtest problem is not related to it, i removed this cards it was the same.
- NEC / Renesas USB3 PCI-E controller, added later later problems, were already here
I tried to exchange some HW to be some that problem is not with it:
- I tried 2 Geforce 730 Gpus
- I tried 2 different ram sticks
- I tried different ram slots
User avatar
ruthan
Postby ruthan » 2019-3-16 @ 21:22
Ok Z170 seems to be in fully workable state.
Win98 OpenGL working, i tried even Rloew AHCI driver to onboard sata booting into Win98 - there are 6 Sata ports if you want.. and there is even demo - $21 bucks for full version, $11 for additional CD rom AHCI driver, but licence is per machine :(..
WinXP are now fully working too - it took some low level Bios ACPI fixing (or you have to using machine with Multiproccessor MPS mode - without ACPI - it need to setup during install or copy installation from other machine - and add some lines to boot.ini and some files to Windows ), even PAT 4+ GB patch is working, i now i have fast WinXP with 8 GB of RAM.. and will add more, when i will transfer machine into production from just testbench project.
Im able also boot into Dos, at least in realmode with external Asmedia Sata 106x with IDE BIOS - it has AHCI bios by default.. so i only problem which prevents me to reach emptiness (of big issue list) is not working Dos SB emulation - i hope that one day will someone break this barrier too.. at least this MB has LPT to some Dos sound minimal solution.. with OPL3LPT or something like that.
BTW in process i found that even someone make NVME disk booting working with XP:
http://reboot.pro/topic/21812-community ... 03-r2-sp2/
I like to see barriers falling in the morning!
User avatar
ruthan
Postby ruthan » 2019-3-22 @ 17:38
I you consider to buy OPL2LPT MB without classic DOS sound support, but with LPT, there is one more reason for it:
viewtopic.php?f=62&t=66024&p=744334#p744334
User avatar
ruthan
Postby ruthan » 2019-4-02 @ 12:16
I added sheet - VideoCardsCoolers to main document. It can help some people,because slots managment is important and for it you need alternative coolers and there are of course also nice for more silent machines.
You can of course report other cards and coolers..
User avatar
ruthan
Postby ruthan » 2019-4-21 @ 18:15
Some change on MB selection landscape, we finally have XP driver for Intel 21x NIC.. before i recommended Realtek LAN, because of XP driver.. and saving a slot, now it doesnt matter and you can select MB depends on other parameters..
https://msfn.org/board/topic/176687-sea ... it-driver/
Thank to Russian Bear..
User avatar
ruthan
Postby ruthan » 2019-4-22 @ 21:52
I added to my sheet, new sheet - FastestSingleSlotCards
https://docs.zoho.com/sheet/published.d ... dc17cafb36
I could be handy, if you dont mind noise, or you really can free 2 slots.. Some of them are crazzy as 1 slot 1070, so of them are reasonable as 730/740.. some of them are just cards with water block additional cards for list are welcome.
User avatar
ruthan
Postby ruthan » 2019-4-28 @ 16:15
My Z170 machine is now botting from NVME, details are here:
http://reboot.pro/topic/21812-community ... ntry210907
User avatar
ruthan
Postby ruthan » 2019-4-28 @ 21:41
Does somebody have experience with these PCI-E NIC + USB, or USB + Sata etc controllers on one card? In theory they could be slot savers..
https://www.ebay.com/itm/StarTech-com-3 ... SwuYVWp6qY
https://www.ebay.com/itm/Ugreen-Gigabit ... SwblZZHlYT
https://www.ebay.com/itm/2-Ports-USB-3- ... SwZ3Ja4yLz
User avatar
ruthan
Postby ruthan » 2019-5-01 @ 22:14
Because i made X79 working for pure Dos Sound i made X58 vs. X79 chipset comparision from multiboot view:
Output in one picture:
User avatar
ruthan
Postby ruthan » 2019-6-14 @ 11:59
I get hand ons Gigabyte B75 Express Chipset MB - GA-P75-D3P, it tried it because Rayer has similar MB with 6x chipset which is capable of Dos audio.. and someone could prefer some classic desktop MB, instead of X58 workstation MBs.. for example because of 65W/95W vs. 130W cpu TDP and need of big cooler or watercooling for quiet X58 machine.
This one has native intel PCI support and USB3 and UEFI, Serial and Paralle port, so its best MB which i was able to research, but news is there is not primary PCI-E slot selection.. i managed to get working so called Dual GPU stunt in XP / Win7 for ATI / Nvidia.. so slower Radeon x550 is in top slots and Geforce 730 is second slot.. but its more annoying than just set bios profile per os with X58.. there you need start with slower card, start XP boot and after that change monitor output on second card.. In XP you need ATI card enable to make it working, in Win7 you need to disable it.
So far, i dunno if Dos sound will work, if native Intel PCI support is actually good or bad thing, so far i tried only quick test with Yamaha 744 it not worked so far, i havent too much time to fiddle with different slots, Aureals etc.
What is good it has - 4x PCI slots, so can for example have Yamaha / Aureal combo +dedicated DOS video card, or some Datapatch PCI capture card inside, which is not very expensive as PCI-E ones.. but it also limiting number of PCI-E slots - so you can have 2x PCI-E gpus + PCI-E GB ethernet or PCI-E USB3 (with is XP capable on board intel isnt) but not both.. I was always a bit affraid of PCI GB cards, that they could eat all PCI bus bandwith.. or will slower than theoretical - 80-100 MB/s which is achievable with my PCI-E cards and NAS.
Other problem is that DDR3 speed is only 1333 i dunno if its MB limitation (Update: Regarding specs in is MB is capable at least 2200) or CPU limit for testing i just using cheap - Pentium Processor G860 dual core.
User avatar
ruthan
Postby Doomn00b » 2019-6-15 @ 16:56
Hey, Ruthan, I've ordered a lot of 3 Quadro 1300 (geforce FX 5900, but PCI-E!) - it's currently stuck somewhere - the german guy I bought them from might be trying to rip me off - hopefully eBay will help out. But anyways, if it works out, and it's actually a lot of 3 cards, would you be interested in one of them, for the purpose of testing in the video-card matrix?
It might be the card which has the best balance between compatibility and performance, for Win98 gaming.
ruthan wrote:What is good it has - 4x PCI slots, so can for example have Yamaha / Aureal combo +dedicated DOS video card, or some Datapatch PCI capture card inside, which is not very expensive as PCI-E ones.. but it also limiting number of PCI-E slots - so you can have 2x PCI-E gpus + PCI-E GB ethernet or PCI-E USB3 (with is XP capable on board intel isnt) but not both.. I was always a bit affraid of PCI GB cards, that they could eat all PCI bus bandwith.. or will slower than theoretical - 80-100 MB/s which is achievable with my PCI-E cards and NAS.
Hmm? What would the purpose of a Datapatch Capture Card, be?
It can be used to upscale from an old g-card to your new monitor?
ruthan wrote:Other problem is that DDR3 speed is only 1333 i dunno if its MB limitation (Update: Regarding specs in is MB is capable at least 2200) or CPU limit for testing i just using cheap - Pentium Processor G860 dual core.
It's the cpu - it's not strong enough to handle anything quicker than 1333 mhz.
Have a look at the specs here:
http://www.cpu-upgrade.com/CPUs/Intel/P ... /G860.html
User avatar
Doomn00b
Postby ruthan » 2019-6-15 @ 19:00
Well, i never had problem with Paypal, they have something like, 180 days return money policy when buyer is not satisfied, yes take as for some proofs, but i never got refused. German is quite rich country and there are quite honest, so i would create some change of rip off by country.. they would be at the end of such list.
Quadro like FX 1300, of course that im interested in.
Datapatch cards, really only about space.. modern machines has only PCI-E slots, so you need PCI-E capture card, quality ones are expensive.. but there are old good ones, quite cheap for PCI, there is long thread for it:
viewtopic.php?f=63&t=26661
I also did some sheet about it, but i never had big knowledge about it:
https://docs.google.com/spreadsheets/d/ ... 1330026216
CPU + MEM - i know, its in original post, Intel is really master of locking features under Paywall.
User avatar
ruthan
Previous
Return to System Specs
Who is online
Users browsing this forum: sirlemonhead and 0 guests
