First post, by K-rnivoro
Well, If MUNT Emulator is able to read external midi commands, I could connect mi Retro PC DB15 Midi connector to a "Munt Only" PC with also a DB15 midi connector. So I wouldn't need those DB15 to DIN adapters. Am I right? http://www.yio.com.ar/contenido.php?artid=23
Reply 1 of 3, by gdjacobs
The ttl out would have to cross over to the ttl input of the target PC.
Reply 2 of 3, by K-rnivoro
That's my idea exactly. Maybe some opto-isolator as you can see in the pic's link.
Reply 3 of 3, by gdjacobs
Or a pulse transformer salvaged from a LAN card.
