Asus P5A-B death ?
Re: Asus P5A-B death ?
Postby amadeus777999 » 2018-12-06 @ 12:58
How many times did you get the 00 boot code? I got it once on a board that is normally stuck at 0d0d.
User avatar
amadeus777999
Postby oldgames79 » 2018-12-06 @ 13:25
amadeus777999 wrote:How many times did you get the 00 boot code? I got it once on a board that is normally stuck at 0d0d.
One time and freeze.
User avatar
oldgames79
Postby amadeus777999 » 2018-12-06 @ 15:02
I mean, every time you boot up it gets stuck at 00?
I had this issue with a faulty graphics card.
User avatar
amadeus777999
Postby oldgames79 » 2018-12-06 @ 15:45
Yes, every time. I have teste a graphic card on the AGP, PCI and ISA bus and I have the same result. All port is defect ?
If It was a faulty video cards there would be a bip sound...
User avatar
oldgames79
Postby amadeus777999 » 2018-12-06 @ 16:16
Sucks, I had to ask because better be safe than sorry.
I have no idea if re-capping may solve this, but give it a go if you got the right equipment.
User avatar
amadeus777999
Postby Mister Xiado » 2018-12-07 @ 04:03
I would have re-capped it from the start, if the board was important to me. I have an Asus P4 board in the basement with capacitors that may as well be olives, but even if I resurrected it with hours of soldering, I would have no purpose for a 2.3GHz 32 bit system.
Image - Where it's always 1992 (or so).
User avatar
Mister Xiado
Postby cyclone3d » 2018-12-07 @ 05:29
Mister Xiado wrote:I would have re-capped it from the start, if the board was important to me. I have an Asus P4 board in the basement with capacitors that may as well be olives, but even if I resurrected it with hours of soldering, I would have no purpose for a 2.3GHz 32 bit system.
How does replacing caps, even all the caps, on a motherboard take hours?
User avatar
cyclone3d
Postby Mister Xiado » 2018-12-07 @ 10:06
Lack of decent equipment multiplies the time it takes to perform any task. Lack of gainful employment exponentially extends the amount of time it takes to acquire such, while simultaneously erasing the motivation to do so.
User avatar
Mister Xiado
Postby oldgames79 » 2018-12-07 @ 21:59
Now I have recapped and the result is the same.
I give up.
User avatar
oldgames79
Postby Tetrium » 2018-12-08 @ 13:23
oldgames79 wrote:Hi,
Help,I recently buy a Asus P5A-B and it doesn't work
When I push the power button ON, the fan of the cpu turn ON but I have nothing on screen, no beep on startup and no POST. The screen is blank.
I have try with different RAM, PSU and CPU (AMD and Intel), I have the same result.
The CPU seems to be work, because it is hot.
Do you think that the MB need to be recap ?
Thanks
Have you done a thorough visual inspection of the board before committing it to a build?
Could you upload some clear pics of the board? Specifically of anything that might look as if damaged.
Since you bought the board, it may have damaged traces or the pins of the chipset may be damaged or bent.
This would be my best guess, seeing as other troubleshooting has proven unsuccessful.
User avatar
Tetrium
Postby oldgames79 » 2018-12-13 @ 08:10
Thanks
Yes, the board seems to be in perfect state.
I upload pics tonight
User avatar
oldgames79
Previous
Who is online
Users browsing this forum: dionb, Dropcik and 14 guests
