First post, by Unknown_K
I have an ATI HD4870x2 card running on a Gigabyte GA-970A-D3 AM3+ board with 4x 1GB DDR3-1333 sticks of RAM (3GB available).
The OS is Win7 32bit since I figured the card was too new for an XP setup (what do you guys think for the OS)?
Anyway I have available an Opteron 1389 (2.9ghz 4 core) or a Phenom II x2 B59 (3.4ghz 2 core). Would this system be better off with a fast dual core or a slower quad core AMD for gaming of the era? I could get a FX chip down the road but I already have a FX-8350 setup (unless I go for a 4 core).
I did unlock the B59 to Quad core but it was unstable doing benchmarks (159W seems kind of excessive for that system anyway). Heatsink is a EVO 212 Hyper. I did try upping the FSB in dual core mode to 225 giving me 3.8+ghz and that seemed stable (overclocking the quite RAM a bit, no heat spreaders).
Basically I am just trying to setup the 4870x2 card to run optimally on an AMD CPU.
Reply 1 of 13, by xjas
If you're running AM3+ & Win7, there's absolutely no reason not to go for the 64-bit OS. AFAIK for the kind of games you'd want to run on a 4870, the higher-clocked dual-core is a good choice, especially if you want to play around with overclocking. OTOH the quad core will give you more breathing room for things like web browsing.
Reply 2 of 13, by Unknown_K
Would I really need more then 3GB of RAM for those games that would run well on the 4870x2? Not worried about web browsing.
Reply 3 of 13, by candle_86
When it was highend, standard was 4gb except on intel which was 6gb, with super users using 8/12gb
Reply 4 of 13, by mothergoose729
Games didn't start being optimized for quad cores until long after the 4870 and phenom quad cores. I don't think there are many cases where 700mhz of extra clock speed is going to really make that much of a difference, but if the only thing you do is play older games, than 4gb of memory and a dual core will be fine.
Some old school benchmarks comparing dual and quad core, circa 2012.
https://www.youtube.com/watch?v=I4PDoy-mi0A
EDIT: The 4870x2 will work find in XP. It was a contender to the 9000 series gerforce cards, which were rebadged g92s. I personally owned a few 4000 series AMD cards at the time, and everyone was using XP back then because Vista was the alternative. Windows 7 release shortly there after.
Reply 5 of 13, by xjas
I actually saw a speed improvement when going from 32- to 64-bit Windows XP on my AM2 build. It was slight, but consistent. I also bumped the RAM up from 4GB to 6GB at the same time. Of course I lost some compatibility in the process, but only on a few titles from before ~2002 (e.g. 3DMark 99 Max).
Titles like Need for Speed 2010 & Prince of Persia 2008 definitely benefited.
Reply 6 of 13, by The Serpent Rider
From my personal experience - avoid 3870x2/4870x2 like a plague. They're not meant for gaming, that's marketing bull. They're meant for pretty FPS counters in benchmarks with horrible frame pacing.
Reply 7 of 13, by cyclone3d
Wasn't frame pacing fixed though? I had a 4870x2 for a short while and it seemed fine to me. If I remember correctly, the earlier drivers were not very good but they got considerably better later on.
I had bought 2 of them to run quadfire, but one ended up being DOA so I RMA'd them and was sent 2x 6870s as replacements.
A single 6870 is going to be slightly faster than a 4870x2 AND you don't have to worry about games working properly with crossfire.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 13, by mothergoose729
cyclone3d wrote:
Wasn't frame pacing fixed though? I had a 4870x2 for a short while and it seemed fine to me. If I remember correctly, the earlie […]
I messed around with crossfire HD 4850's in the day, and from what I remember games did feel a little bit jittery. More than that though, crossfire was a giant pain in the ass to set up and get working properly. Personally, I would rather have a single GTS 250 for playing games of the era, but if OP already has the card might as well use it.
Reply 9 of 13, by cyclone3d
At one point I had a 4850 and a GTS250 in the same machine and set up a hybrid PhysX setup.
For PhysX games, I would use the 4850 for rendering and the GTS250 for hardware PhysX.
A really weird thing about that setup is that I could start up a game in windowed mode or switch to windowed mode and then drag to the other screen and the rendering load would switch to the other card.
That part just seemed strange to me as I would have thought that switching between ATI and nVidia cards mid-game would cause issues but it didn't.
YMF7x4 Guide
Reply 10 of 13, by The Serpent Rider
Frame pacing issues were never addressed before Radeon 7990. By that time even Radeon 6990 was moved to legacy.
Reply 11 of 13, by Unknown_K
I guess I should have mentioned I have quite a few old games systems because I like to build old systems as much as use them.
While I have a few SLI setups (8800 gts 640MB, 9800 gtx+ , 8800 GS, etc) I don't have any crossfire. The board I am using supports crossfire and I initially set it up with 2 x 4850's that worked OK, but the cards must be getting old because they run hot as hell even after cleaning and new heatsink compound. So I decided to use my 4870x2 instead.
I do prefer single card options and have quite a few of them as well but SLI/CF is fun in the era where it was actually supported.
Reply 12 of 13, by Koltoroc
oh, they were addressed before the 7990, most driver releases had a line somewhere about crossfire issues or "microstutters" It just took until the 7990 until they were minimized enough to not be a major concern anymore. However, they were never fixed. Heck there are still issues today with frame pacing and crossfire just not anywhere what they used to be and on par with similar issues with SLI.
Reply 13 of 13, by SPBHM
actually no, they updated the frame pacing on as far as Radeon HD 5000 series which were still supported at the time (until late 2015, the whole frame pacing with SLI vs CF and AMD fixing it happened prior to that),
I haven't seen it tested properly, but that's what an AMD rep said.
but HD 4870 would was left out anyway.
as for system specs, when the 4870 was launched 2GB were still the norm for mid to high end gaming machines, also something like the E8400 (which your PII X2 is not all that different) were common for this application;
perhaps the person buying the X2 version would be likely to have something a little better, but not that it made much of a difference back then.
