Re: Bought these (retro) hardware today
Postby oeuvre » 2019-1-13 @ 13:56
Infinitely better... doesn't feel mushy.
Retro PC Intel i7 2600, 16GB, AMD FirePro V5800 1GB, SSD + HD, XP/7
Main Desktop AMD Ryzen 3700X, 32GB, AMD RX580 8GB, NVMe SSD + HD, 10
User avatar
oeuvre
Postby detritus olentus » 2019-1-13 @ 19:10
Found boxed visual basic 5.0 (not that I have any idea how to use it) and this cool handheld usb trigger mouse.
https://archive.org/details/@detritus_olentus
Where are my other retro New Jersey Folk?
AIM Phoenix: novusrexrgis
User avatar
detritus olentus
Postby Windows9566 » 2019-1-14 @ 04:50
Finally found a IO shield for my Intel Advanced/ML board
1995-TC430HX,P100,32MB-RAM,CL-GD5446,CT1600
1996-VX97,P133,32MB-RAM,TRIO-64V+,CT1740
2017-ROG-B450F,R5-1600,16GB-RAM,GTX-1060
User avatar
Windows9566
Postby luckybob » 2019-1-14 @ 05:01
Those are "standard" ATX shields.
its just the standard that came before THE STANDARD. Think USB 1.0
User avatar
luckybob
Postby Windows9566 » 2019-1-14 @ 07:03
luckybob wrote:Those are "standard" ATX shields.
I thought the standard IO shield was like
PS2------------LPT----------JOYSTICK---
PS2--USB--COM---COM---AUDIO PORTS
User avatar
Windows9566
Postby luckybob » 2019-1-14 @ 09:54
The key word I used was BEFORE. The one Windows9566 linked was the very first version. USB killed that version.
You only ever see the first version on early Pentium motherboards (and Pentium Pro).
User avatar
luckybob
Postby Thermalwrong » 2019-1-14 @ 13:07
The new old stock 486 motherboards from Ukraine arrived today :D
The box was a bit ripped but they were well packed and it's weird seeing a 486 motherboard look this new & clean. The one on the left I already have and bought solely to have a read of and digitise the manual, since that's not online in its complete form anywhere.
Now to see if I can get PS/2 mouse working on the FIC 486 VIP IO2 board by just adding the headers. I spent all that time trying to fix that Asus PVI-486SP3 board and now a good source of equally capable boards has appeared :D
Thermalwrong
Postby appiah4 » 2019-1-14 @ 14:38
Image Image
Thanks to the kind souls on Vogons who gave me the heads up to the eBay seller selling these blank back plates for real cheap!
Does anyone happen to have the blueprints for an AT backplate? What diameter hole, at what location etc? Also, what do I cut a backplate with? Some Dremel drill pit would do?
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688
i486:U5S-33|8M|GD5428|MED2000/MUNT-Pi
i586:P133|32M|S3T64+/MX2|V1|CT3980/32M
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby oeuvre » 2019-1-14 @ 14:44
use a plasma cutter
User avatar
oeuvre
Postby liqmat » 2019-1-14 @ 14:49
appiah4 wrote:Image Image
I have a bunch of new AT backplates for the motherboards I have. I could scan one in for you or measure. Let me know.
User avatar
liqmat
Postby appiah4 » 2019-1-14 @ 14:56
oeuvre wrote:use a plasma cutter
I was hoping it would be the same diameter as my lightsaber.
liqmat wrote:I have a bunch of new AT backplates for the motherboards I have. I could scan one in for you or measure. Let me know.
Hey I would definitely appreciate that if you have the time and all.
User avatar
appiah4
Postby PcBytes » 2019-1-14 @ 15:05
Thermalwrong wrote:The new old stock 486 motherboards from Ukraine arrived today :D
That barrel battery in a spot where a CR2032 battery should be is by far the most stupid thing I've seen today.
Who thought that would be an great idea? Especially since these are notorious to leak and kill traces.
Main: Xeon X5450, 8GB RAM DDR2, DFI Lanparty DK P45-T2RS
Wolfram: C2D E6750, 2GB DDR2, ASUS P5K-SE/EPU
R.A.I.D: Pentium 4 2.8GHz, 2GB DDR400, ASUS P4C800-E Deluxe
Totem: Pentium S 166MHz, 128MB RAM, Totem TM-586TX4
Voodoo: AMD K6-2 500MHz, 128MB RAM, LuckyStar 5MVP3
User avatar
PcBytes
Postby liqmat » 2019-1-14 @ 15:06
No worries, this way you could at least print yourself a paper template. I would send you one, but I don't even have enough for my motherboards unfortunately.
User avatar
liqmat
Postby appiah4 » 2019-1-14 @ 15:08
liqmat wrote:No worries, this way you could at least print yourself a paper template. I would send you one, but I don't even have enough for my motherboards unfortunately.
No need, punching a hole in these shouldn't be too hard, I just need to know where and how big :)
User avatar
appiah4
Postby Thermalwrong » 2019-1-14 @ 15:08
At least they're easy to desolder and replace with a regular CR2032 holder :)
The barrel battery on the MS-4143 is juuuust about to leak, just like my other one - that's getting removed and replaced this evening.
For the ATX to AT backplate, I measured that a couple of weeks ago while making some up from similar blank ATX plates, try these dimensions:
Looking from the back of the case:
Going from the edge of the ATX case area, so ignoring the area to hold the backplate in place (but not the raised edge)
Top: 24mm
Bottom: 7mm
Left: 110mm
Right: 33mm
Thermalwrong
Postby Munx » 2019-1-14 @ 15:56
Windows9566 wrote:Finally found a IO shield for my Intel Advanced/ML board
Congrats on obtaining unobtainium. My P200 Build has been sitting shield-less for years...
EDIT: a quick search for IRDrive on ebay and I found one finally!
My builds!
The Underdog - The budget K6
User avatar
Munx
Postby liqmat » 2019-1-14 @ 16:05
appiah4 wrote:Hey I would definitely appreciate that if you have the time and all.
For what it's worth.
User avatar
liqmat
Postby SW-SSG » 2019-1-14 @ 20:16
Oh neat, I was watching the listing for the FIC for a while but ultimately decided against it. Nice to see that it was the real deal...
User avatar
SW-SSG
Postby appiah4 » 2019-1-14 @ 20:54
Much appreciated, thank you.
User avatar
appiah4
Postby GigAHerZ » 2019-1-15 @ 21:15
Just got the Asus P/1-P55T2P4.
It has 256KB of on board cache and has COAST slot for additional 256KB of cache... and i apparently had one of these just laying around from decades ago!
Nice board, lots of voltage regulation options, fsb and multiplier setting etc.
Downsides are that it doesn't accept SDRAM and it has dallas chip. Otherwise it could replace my Pentium machine's motherboard. (I'm keeping 386, 486 and P1, one of each for myself and everything excess goes to trading and to museums)
Got it from auction site, probably it would have went to landfill, but i was able to save it for few bucks. :) (And it also had 2x8MB 72pin ram, never hurts...)
User avatar
GigAHerZ
PreviousNext
Who is online
Users browsing this forum: Deksor, Durandal, Tiido, WinSxS and 18 guests
