First post, by SirNickity
Story time, boys and girls. 😀
In the early 90s, when I was a young teenager, I had my very own AST Advantage 486SX/25 desktop PC. It was a bare-bones model -- 80MB HDD, 2MB RAM, no CD-ROM, no audio. But it was mine, and mine alone, and I loved it dearly. Now, I always have been, and always will be an audio nerd, so I managed to convince my dad into giving up the Sound Blaster Pro that he had bought for the family 386. And that was great. Right up until a friend of mine got a Pro Audio Spectrum 16.
This friend of mine had a gadget-loving dad, and he always had the latest and greatest. First person I knew that had a PC. First person I knew that had a CD-ROM. A laser printer. A tape backup. All the best toys. 😁 So, when I dropped by his house and he showed me his brand new 16-bit audio card playing MODs through the bundled Trackblaster Pro software, I was stunned. SO COOL. WANT. 😳
The SB16 was still brand new and more expensive (and didn't have that beautiful 256-color VGA MOD player!), so the PAS16 became the item of my desire. Top of the list. Soon -- I think as a Christmas present -- I got my very own*, and so dad got his SBPro back. (* Well, Pro Audio Studio 16, technically -- but same thing.) My dad eventually upgraded his computer with a Sound Blaster 16 multimedia kit -- SB16, Panasonic 2x CD-ROM drive, and new speakers. We had little wars over whose was better. He had the nice Yamaha Super SAPI FM driver for Windows, but mine was cooler because... well, it just was, OK? 😉
So here we are, years later, and I'm back into retro PCs. I'm planning out my spread of machines, and the cards I will put in each one, and figured -- hey, it would be cool to have each platform represent a point in time, and the hardware I would've had -- which changed as we swapped parts, and one of us upgraded and handed down the older stuff, so plus or minus a little fudge factor. Ergo, my 386 build will have the SBPro, the 486 build will have the SB16 and 2x CD-ROM (which I later inherited because it could rip audio CDs, while my CD-620E Hex Speed IDE drive could not), the Pentium will have a PAS 16 because I rocked that card until upgrading to a Cyrix 5x86 and then an AWE32....
I don't have my original PAS16 anymore, so I went to Ebay and found one. It arrived with a bit of corrosion on the bracket and the I/O ports. No problem, the bracket cleaned up nicely; the game port is a standard footprint and was easily replaced; the audio jacks are too -- except there are a few different common heights, and the exact match was NLA from the parts houses. So I got something close and figured I would enlarge the holes in the bracket to accommodate. Well, then I had no end of issues with the card.
For one, it took a while to resolve all the resource conflicts, but eventually I got Win95 to select a config where everything worked. Then I ran into the second problem.
The sound was barely audible, and running MUCH too fast. Some research indicated that the speed issue was a known side effect of not having a -5V rail. Sure enough, I was using an ATX supply with an AT converter cable. After securing a standard AT supply, that problem was solved.
The sound was STILL barely audible, though. Crackly, whisper quiet, heavily distorted. Huh. Maybe I need to replace the caps? So I did. (Need to swap them out again, though -- the larger values I had on-hand were too high on the voltage rating, and thus physically too large to fit in a single slot form factor.) No help -- sound was still quiet and terrible.
Then I read a post where someone mentioned off-hand that the PAS16 had an odd grounding scheme, where the audio ground was actually tied to the bracket and grounded to the chassis when the card was installed. Well, mine was still missing the bracket! So, I finally got around to testing this theory out.
Don't mind the disaster area of a workbench here...
267.29 KiB
In this case, I just used an alligator clip to ground the bracket fastening pad to the AT keyboard port. But, this was a hybrid AT/ATX board, and I was using another ATX supply without -5V, so I had to improvise:
234 KiB
Some day, I might create a short ISA card that back-feeds -5V from the -12V rail. It would come in handy in cases like this.
At any rate, I can now report that the PAS16 is FULLY functional, and works like a champ! 😎
I even sat down with some headphones and listened to the MOD files bundled with the Trackblaster Pro player. .... Now why would they include MODs that used looped samples if TBPro didn't handle loop points correctly? Some of those sample files sound awful with this player. I can say that, now, visualization has come a long way, and TBPro is not a very full-featured player. (4 channel limit? C'moooonnn...) I later discovered Inertia Player (which frequently sang out of tune), and then later Cubic Player (viva la CP!), and then MOD4Win, and WinAMP.... heck, I still enjoy MODs. 😀 So TBPro isn't quite the hardware seller it would've been for me back then, but it was definitely a step up from Modplay -- which is what I would've been using before.
All in all, there's not much about this card that is just better than a Sound Blaster of equivalent vintage. The allure of the PAS16 was definitely a period thing -- what was available for CD-quality PCM at the time, the onboard SCSI controller is a nice bonus, price point was good, etc. Still, I might have to build another PC just to keep this bad boy in use. (The Pentium has since inherited my old AWE32, and I think I like that better for late DOS and early Win95 games, so this will have to go elsewhere.)
Reply 1 of 5, by Tenorman
Good work. I have a couple of PAS16s as well, though I'm not currently using one in anything. They are good cards if you are looking to stray off the beaten path a bit yet still have something very usable. Good quality hardware/software package, many of the major games from the time natively support PAS16, and good SB 1.x support to fall back on.
[Compaq Presario 633 | DOS 6.22 / Win 3.1 | DX4 100 Overdrive | 28M RAM | SB16 CT2770A | SPEA Media FX (Soundscape S2000) ]
[GA-6BXC R2.0 | Win98SE | Via C3 Ezra 866 | 384M RAM | TNT2 32M | Voodoo2 8M | SB32 CT3670 | Ensoniq Soundscape Opus]
Reply 2 of 5, by cyclone3d
Sweet!
As far as creating a card to take care of the -5v... not worth it one bit.
There are ATX to AT adapters available that also provide the -5v.
Looks like the seller is currently out unless you want to buy a 5-pack though.
https://www.ebay.com/usr/antronst
He does have the ATX 24-pin to ATX 20-pin with added -5v available though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 5, by Intel486dx33
I just ran into this same problem.
The PAS16 worked fine in my ATX 486 socket-3 motherboard ( PCchips M918i ) running Win95c with vanilla drivers , but NOT in my ATX Asus P3 motherboard running Win98se.
472.74 KiB
    110.99 KiB
Reply 4 of 5, by SirNickity
That was the motivation for the thread. I've happened across some vital info that gave me hope the card was still alive. Otherwise I probably would've thrown it out thinking it was unsalvageable, when all that was really wrong was a missing analog ground and -5V rail (though that problem did actually occur to me before I learned how often it's an issue with certain sound cards.)
As for the ATX extensions -- I know, I've recommended those as well. 😀 But, as a quick fix where I can shove a PCB into the slot and use the combination of bench supplies that I already have.. Kinda sounds handy!
Reply 5 of 5, by Intel486dx33
Yeah, I really like the sound of this PAS16P once it is all setup and working properly.
It has kind of a 3D sound. Very Clear and Crisp and Snappy.
It's defiantly different from the SB16.
With Vanilla Win95c Media Vision drivers.
