DOSBox 0.74-2 has been released
Reply 40 of 54, by digger
DosFreak wrote:
I appreciate the effort Jason did in writing this blog and trying all of that out, but I'm frankly surprised that he didn't find out that SciTech Display Doctor is freeware these days. A little bit of googling would have turned that up pretty quickly.
Although to be fair, apparently, the legal status of version 7.0 beta, which is said to be the only version that works with recent versions of VirtualBox, is less clear. I can't link directly to the article that talks about it, since it shares a download link and a legally ambiguous license key for that version.
Reply 41 of 54, by lightmaster
Congratulations DOSBox Team and everyone that made this possible.
Reply 42 of 54, by cyclone3d
Trying to compile 0.74-2 with Visual Studio 2017.
All libs have been recompiled with 2017 to fix issues with toolsets, certain functions, etc.
I am getting these errors when it goes to link:
1>gameblaster.obj : error LNK2001: unresolved external symbol "public: __thiscall saa1099_device::saa1099_device(struct machine_config const &,char const *,class device_t *,unsigned int)" (??0saa1099_device@@QAE@ABUmachine_config@@PBDPAVdevice_t@@I@Z)
1>gameblaster.obj : error LNK2001: unresolved external symbol "public: void __thiscall saa1099_device::control_w(int,int,unsigned char)" (?control_w@saa1099_device@@QAEXHHE@Z)
1>gameblaster.obj : error LNK2001: unresolved external symbol "public: void __thiscall saa1099_device::data_w(int,int,unsigned char)" (?data_w@saa1099_device@@QAEXHHE@Z)
1>tandy_sound.obj : error LNK2001: unresolved external symbol "public: void __thiscall sn76496_base_device::write(unsigned char)" (?write@sn76496_base_device@@QAEXE@Z)
1>tandy_sound.obj : error LNK2001: unresolved external symbol "public: void __thiscall sn76496_base_device::convert_samplerate(int)" (?convert_samplerate@sn76496_base_device@@QAEXH@Z)
1>tandy_sound.obj : error LNK2001: unresolved external symbol "public: __thiscall sn76496_device::sn76496_device(struct machine_config const &,char const *,class device_t *,unsigned int)" (??0sn76496_device@@QAE@ABUmachine_config@@PBDPAVdevice_t@@I@Z)
1>tandy_sound.obj : error LNK2001: unresolved external symbol "public: __thiscall ncr8496_device::ncr8496_device(struct machine_config const &,char const *,class device_t *,unsigned int)" (??0ncr8496_device@@QAE@ABUmachine_config@@PBDPAVdevice_t@@I@Z)
Do I need precompiled libs for the gameblaster and tandy sound or is something else going on here?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 43 of 54, by Qbix
Rank DOSBox Author
DOSBox Author
Good question. I probably forgot to add the sa and sn files to the project file.
Go to hardware/sound in your project navigation and click on add. Add all *.c and *.h files from the folder hardware/mame. That should fix it.
Water flows down the stream
Reply 44 of 54, by cyclone3d
That did it! Thanks! 😀
YMF7x4 Guide
Reply 46 of 54, by cyclone3d
DosFreak wrote:
Reminds me that I need to update my VS guide and test with the latest VS version.
I'm working on build instructions for 2017 as well as a full project package.
Pretty much just have to tweak a few settings as well as change include and lib folders to relative paths for the project package.
This is in preparation for my optimization "fork" which should yield a nice 20%+ reduction in needed CPU cycles. Guessing more overall as the last time I did this was years ago and only optimized a few of the source files.
You looking at trying out VS 2019 Preview?
YMF7x4 Guide
Reply 47 of 54, by DosFreak
Yup 2019 and need to update my guide with the mingw ones and then finish and upload the linux guide.
Then the OSX guide which should be fun since all I have is OSX in vmware but should be enough. Don't think you can cross compile for OSX from linux.
Make your games work offline
Reply 48 of 54, by junglemontana
I just noticed that the Dosbox repository package on my Arch Linux (64-bit) system was updated and it seems to work nicely. Dynamic core works, and freezing/crashing issues with GTA are gone too. Thanks!
Reply 49 of 54, by dr.zeissler
I normally do not use dosbox, but I randomly do a test and then I remember why I do not like it.
Yesterday:
iMac 17" 10.6.8 two ready to useable ports I got from the web:
- Biomenace 1-3
- MortalKombat3
Both have the same problem. They are far from being smooth like on the real machine.
Biomance: Vertical-Scrolling is 100% smooth on the real machine, in my DosBox-Port it stutters.
Mortalkombat3: Horizontal-Scrolling in Game stutters obviosly, and the vertical-scrolling when choosing the "difficulty" too.
Are these examples a configurational error, or are these inevitable?
Btw: Adlib sounds really bad too (LostVikings e.g)
Reply 50 of 54, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
useable ports? What do you mean? Did you use them with Dosbox 0.74-2 or with something else? Not to mention that these games likely need more horsepower.
Sound might be better in a SVN built (as mine in the signature)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 51 of 54, by James-F
That's what you get with 70Hz games on a 60Hz display, stuttering.
They are innevitible unless you create a new resolution in your OS with 70Hz (like 1920x1080 @ 70Hz) and run dosbox.
Yes MK3 needs more power.
Adlib sounds great in dosbox.
Reply 52 of 54, by keenmaster486
DOSBox is a powerful tool, my son. You must use it wisely or you will only harm yourself.
World's foremost 486 enjoyer.
Reply 53 of 54, by dr.zeissler
Biomenace is from GOG, I use DB universal 0.74 (rather old)
