Good DOS WYSIWYG word processor?
First post, by keenmaster486
Can anyone recommend a good DOS word processor?
I have used MS Word 5.5 and 6.0, in addition to Word Perfect 6.1 (the only WYSIWYG word processor for DOS that I know of), but I'm looking for something a little better. Here's what I'm looking for specifically.
  • Support for RTF format
  • Graphics mode WYSIWYG with VGA and maybe VESA compatibility
  • More of a minimalist interface, similar to Windows 95's WordPad as opposed to Word 97, for example.
  • Does not require 386/486/Pentium
  • TrueType font support with good rendering. A lot of word processors for DOS will render the text with chunky blocks stuck on the letters because they can't scale them properly.
Beats me if this exists somewhere out there. If it doesn't, I'll be wanting to make it myself 🤣
World's foremost 486 enjoyer.
Reply 2 of 20, by retardware
Ventura Publisher (which ran on GEM) ran nicely on 8088 DOS PC, though not at the speed people expect nowadays.
In the 1980s I used it myself.
But that was before things like RTF, TT, so it does not fulfill your requirements.
Reply 3 of 20, by Damaniel
The first of your requirements are doable in theory (and are something I've kind of wanted myself for a while), but I don't think a 8088/286 is going to be able to render TrueType glyphs at any usable speed, even with an 8087/80287.
Reply 4 of 20, by keenmaster486
Maybe the TrueType thing is not as important. Mostly I am concerned with the user interface; I don't want flashy, confusing buttons screaming at me from the screen and taking up 3 inches of vertical space; at most maybe the font settings and bold/italic/underline, and bulleted/numbered lists (with options to customize things, of course).
Word Perfect 6.1 is honestly the closest I have seen to this; it just has non-standard everything! I.e. not like MS Word, really. For example it handles block text selection in the most counterintuitive way. Also the way it renders fonts makes them look not that great.
Reply 5 of 20, by yawetaG
You know you can customize the menus and button bars in Word 6.0, right?
Reply 6 of 20, by keenmaster486
Word 6.0 is a fake WYSIWYG interface; only supports displaying bold/italic/underlined, in the system font.
Reply 7 of 20, by dr_st
Uhm, what?
Reply 8 of 20, by yawetaG
Then your installation is screwed up, because that plainly isn't true. I have the Microsoft manual to prove it.
Reply 9 of 20, by keenmaster486
In pure DOS? Obviously Word 6.0 for Windows will do the full shebang but I thought the DOS version was limited to the display capabilities of Word 5.5.
Reply 10 of 20, by dr_st
I believe you may be right; I actually had no idea (or forgot) about the existence of Word 6.0 for DOS; everyone just remembers Word 6.0 for Windows. It's very confusing to have two applications with the same name, which are actually very different!
Reply 11 of 20, by yawetaG
Well, you didn't specify it was the DOS version.
But yeah, look at programs for GEM; there's some nice stuff.
You could try finding a PC version of Locoscript, which is not exactly WYSIWYG, but should support multiple fonts and even has the ability to design your own...
Reply 13 of 20, by keenmaster486
I will look into GEM stuff! I vaguely remember using GeoWorks at some point. I'll look at that as well.
Reply 14 of 20, by KormaX
Well, If you are still interested, after one year, then perhaps FLWRITER is what you are looking for. Search for it exclusively, or search for FLTK (for DOS). The whole FLTK package contains a spreadsheet editor, a calculator, PDF viewer, etc., ad FLWRITER itself. It supports TTF, various formats for import and exports, writes PDF files and do cool stuff. Has a limited support for bi-directional script, but does not support crsive scripts, like arabic, uyghur-mongolian, etc. Yet, it mostly meets your requirements.
May the DOS be with you!
Reply 15 of 20, by KormaX
Well, If you are still interested, after one year, then perhaps FLWRITER is what you are looking for. Search for it exclusively, or search for FLTK (for DOS). The whole FLTK package contains a spreadsheet editor, a calculator, PDF viewer, etc., ad FLWRITER itself. It supports TTF, various formats for import and exports, writes PDF files and do cool stuff. Has a limited support for bi-directional script, but does not support crsive scripts, like arabic, uyghur-mongolian, etc. Yet, it mostly meets your requirements. I think its Unicode support must be restricted to the BMP blocks, as most modern scripts, even CJK is supported, but Hungarian runics are not.
Reply 17 of 20, by Caluser2000
keenmaster486 wrote on 2019-03-12, 21:36:
Can anyone recommend a good DOS word processor? […]
Have you started your own yet? The request was pretty much a pipe dream in the first place.
Reply 18 of 20, by keenmaster486
Caluser2000 wrote on 2020-06-04, 20:55:
I'd love to, if I can find the time =)
Reply 19 of 20, by Jorpho
WordPerfect's DOS WYSIWIG was big smoke back in the day.
Did Symphony 3.0 have WYSIWIG capabilities? It seems to be mostly forgotten.
I was also thinking of Ami Pro, but I don't think that ever had a DOS version.
