First post, by dionb
- l33t++
I was half way through making a post asking for help when my final step to rule out everything possible actually worked. It was pretty farfetched though and I had exactly zero hits in Google on it, so I'll share it here for future reference.
Situation:
Digital Venturis 575
P75, SiS 5501 chipset, 8MB onboard RAM, S3 Trio64 onboard. Empty DS12887 RTC gave battery error at POST and of course lost settings when power went off.
Previously had a Seagate ST3660A 544MB HDD. After booting into BIOS and autodetecting HDD, it booted into an old Win95 install. However I needed that drive for something else (promised someone a 540MB HDD and the other one was riddled with bad sectors). Then put system away for a while.
This evening I wanted to get it ready for sale/donation/whatever to offload the damn thing. No luck. What didn't work?
- booting from HDD after autodetecting in BIOS.
- running fdisk from floppy after booting into DOS 6.22 - get an "Error reading fixed disk" error.
- booting into DOS 7.1 from floppy - just hangs after POST after briefly trying to access FDD.
Nothing I tried in terms of settings helped, I'd already removed all other hardware from the system, tried four different HDDs and two different known-good IDE cables.
So... what was it?
The damned RTC. I had a recent (2017 date code) DS12887 RTC lying around I had intended for another system I eventually wasn't able to use it in (DS1387 can't be replaced by DS128(8)7... so I got out the Dremel and did it the hard way with the DS1387), so stuck that in the Venturis. No more battery error, but more importantly, after doing the exact same settings in BIOS as before, DOS 7.1 did boot, DOS 6.22 fdisk did find the disk (and C: was there anyway) and I could boot from it.
Pretty odd that not having a working battery could have this effect, but I'm completely puzzled as to how it was able to boot with the ST3660A, despite the 1995-dated RTC being just as dead when that drive was in the system. Anyway, if you have a Digital Venturis or similar system and hit this sort of stuff, try a working battery first 😉
