First post, by alienkidmj12
im looking for a 2mb dram memory module for a mach64 memory card, it has to be dram memory modules.
its to fit on the card to the right,
Reply 1 of 18, by Anonymous Coward
This can be tricky. The modules were normally not used on the VLB or ISA versions of this card, but they were used fairly often on the PCI version. Normally the most economical way to get one is to buy a PCI card with the expansion, and swap it. Unfortunately, there are several different versions of the upgrade, and only a few of them work on the ISA/VLB version. You should probably try to pay close attention to the part numbers.
To be honest, it's not really worth the upgrade on the ISA version, because anything above 1024x768 will be too slow to use.
Reply 2 of 18, by blurks
Hey that's awesome and what exactly do you expect us to do/change about it?
I learned in school that a call for help usually begins with a question. I don't see one here.
Reply 3 of 18, by Baoran
I never understood why to upgrade memory of any isa video card. They are not fast enough to run anything at higher resolutions that would require more memory. Generally even 512Kb is more than enough for any isa video card.
Reply 4 of 18, by dionb
For gaming you are correct, but certainly back in the day when these things were current. gaming was very much a niche thing on PCs (people used SNES or Amiga for that). Most PC graphics was about the Windows desktop. With Windows 3.11, 1MB meant 800x600@16b or 640x480@24b, 2MB meant 1024x768@16b or 800x600@24b, but for 1024x768@24b/32b you needed 4MB. That is why an upgrade to 2MB almost always made sense, and anyone doing anything requiring true colour could use 4MB too.
You would have to go right to the end of the PCI VGA era before gaming could use 4MB sensibly let alone something more, but even back in the very early 1990s the extra RAM made sense on ISA or VLB (if you could afford it) for productivity, which was why people bought PCs in the first place in those days...
Reply 5 of 18, by alienkidmj12
the adaptor on the left is for an old atari, going isa is the only solution unfortunately, the adaptor converts isa to a format the atari can understand. i was under the impression that all pci cards using vram and not dram, i will do some more digging,
dave
Reply 6 of 18, by kixs
Your card uses VRAM memory. Non the less you need an expansion card with the same memory configuration. Only an early PCI version used the same memory. Later ones are not compatible.
Is it useful? I don't know. This card is the fastest performing ISA card for Windows and I'm yet to try how it performs with 4MB at higher resolutions/color depths.
Reply 8 of 18, by rasz_pl
ISA MACH32 was the fastest Windows graphic card in 1992, as in 2 times faster than Vesa Local Bus S3 901. You dont need fast bus when all graphic assets are sitting inside cards memory, whole point of graphic accelerator is offloading calculations away from CPU.
Reply 10 of 18, by alienkidmj12
just so happens i have one of these, wonder if its compatible,
Reply 11 of 18, by cyclone3d
Maybe one of these:
https://www.ebay.com/sch/i.html?_from=R40&_tr … ati+ram+upgrade
It looks like the upgrade card might be the same as the one for the PCI MACH64:
http://www.vcfed.org/forum/showthread.php?449 … -upgrade-module
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 12 of 18, by Anonymous Coward
I am somewhat certain the cards with the 109-31600-XXX part numbers do not work...at least the one I tried on mine did not.
Reply 13 of 18, by kixs
It's not.
Reply 14 of 18, by noshutdown
i have an 2mb dram oem version of mach64 isa which can't be upgraded. its a bit slower than the fastest isa videocards(cirrus5434, tseng et4000/w32i) so i doubt if its worth the trouble.
Reply 15 of 18, by kixs
Depends on what you're after... Mach64 ISA is a bit slower in DOS but much faster in Windows.
Reply 16 of 18, by noshutdown
i doubt on that, even with xing mpeg player its a bit slower than the cirrus.
Reply 17 of 18, by kixs
That's what my tests show. But I only use Winbench and Wintach for testing 2D operations.
I've done this a few years ago. I think the Mach64 ISA is a DRAM version. Now I also have VRAM and it's around 20% faster in Windows.
I've tested with fast 5x86 processors. With something like 386 things could be much different. Might redo some tests in the future...
Reply 18 of 18, by Anonymous Coward
I don't own the Mach64 DRAM for ISA....but I am pretty skeptical that it's slower than a cirrus logic in Windows. Are you certain the card is configured properly? Have you run vconfig?
