First post, by renz20003
While flashing it started failing writing blocks, I suspect a bad floppy disk. Didn’t find any jumper settings to get into a recovery mode. Anyone have any ideas on if this can be saved?
Reply 1 of 16, by renz20003
It’s an award bios chip if it helps
Reply 2 of 16, by gerwin
When the motherboard BIOS is corrupted to the point that the board no longer boots up, you need to remove the BIOS chip and use another device to rewrite the BIOS EEPROM properly.
There are several devices that be used to rewrite a BIOS EEPROM:
- External EEPROM programmer.
- Hot Flashing using another motherboard with the same BIOS socket: Guide. Warning: Be careful with this.
- Use a Network Card with EEPROM socket on another computer. Never tried this myself..
Software for DOS: Uniflash
Reply 3 of 16, by renz20003
gerwin wrote:
When the motherboard BIOS is corrupted to the point that the board no longer boots up, you need to remove the BIOS chip and use […]
- Hot Flashing using another motherboard with the same BIOS socket: Guide. Warning: Requires skill and attention.
It does try to access the floppy before it starts freaking out, I’ve read that some AMI BIOS could be reflashed in that case.
Thanks for the info
Reply 4 of 16, by gerwin
You're welcome.
It does try to access the floppy before it starts freaking out, I’ve read that some AMI BIOS could be reflagged in that case.
I don't know what reflagging is..
I hotflashed some BIOS chips yesterday. One other tip I can give, is to put a bit of ribbon cable (like 7cm in length) underneath the EEPROM before inserting it into the socket. This way it is easy to remove an EEPROM.
UniFlash can be found here: http://www.rainbow-software.org/uniflash/
Reply 5 of 16, by renz20003
gerwin wrote:
You're welcome. […]
You're welcome.
*Reflashed.
Ever have any luck with a usb EEPROM burner?
Reply 6 of 16, by gerwin
That is the most proper way. But I don't have any such device myself.
Reply 7 of 16, by gbeirn
Where are you located? I could mail you a new burned eeprom.
Reply 8 of 16, by renz20003
Ohio
Reply 9 of 16, by gbeirn
Got a link to the BIOS or can attach it here? I should be able to burn one and drop it in the mail tomorrow.
Reply 10 of 16, by renz20003
https://www.wimsbios.com/biosupdates/chaintech/6Z69KC3A
Your sir are a gentleman and a scholar
For whatever reason I can’t send Pm’s
Reply 11 of 16, by gbeirn
I think you need a minimum of 10 posts.
I can't figure out how to use that site to download, it wants me to buy some program. With some googling I found 6btm0505.bin as the most recent so I downloaded and will burn that for you.
Reply 12 of 16, by renz20003
That should work
Reply 13 of 16, by renz20003
I saw your pm but it will not let me reply, either need more posts or the mods haven’t enabled it yet
Reply 14 of 16, by gbeirn
I PM'ed you my email address.
Reply 15 of 16, by PC Hoarder Patrol
Possible word of caution - do you know your board revision as some of the later bioses don't support Coppermine on early revisions. According to Chaintech it looks like anything below revision E is out for Coppermine support with the later bioses and some at E and above are only with specific board IC support
Intel Coppermine CPU supported model listing […]
This table just offer old chipset for Coppermine CPU support.
6BTM - E / F / G / H / J / K version full support, L / M / N version support only with HIP6004BCB ( U9 )
Also, there is a later bios revision https://web.archive.org/web/20020215082007/ht … MB/6BTM0817.EXE
08/17/00 Please don't use Coppermine CPU after update this BIOS on C/D version ! Changes made in this update: •Support EON 29f0 […]
•Support EON 29f002nt flash ROM.
•Update micro code.
Reply 16 of 16, by renz20003
Did you get my email and would you like some compensation for the effort?
