First post, by borichka
Hi All,
I got Gravis UltraSound Classic card v2.4 in "untested" condition. It passes all the tests including RAM test, however I'm unable to get any sound out of it.
I tried MIDI demos from the driver folder, tried games with GUS and SB support, nothing.
When card initialized I do hear clicks from both Speaker output and Line output.
I replaced all the jumpers and checked that they are actually working.
Reinserted all the chips except GF1, same with memories.
Checked the card with two different PCs and different drivers, but still no sound at all.
How would you suggest starting with finding the problem with this card?
Any help is highly appreciated!
Thank you in advance!
Reply 1 of 18, by root42
Can you post high res pictures of back and front? So one can visually inspect for damage/missing components.
Also are you sure you plugged into the right audio jack? I once plugged my speakers into the line in...
Try CAREFULLY pushing on components while playing music to figure out if there are any cold solder joints/broken joints that make bad contact.
YouTube and Bonus
Reply 2 of 18, by borichka
I plugged into two "top" jacks, but also tried with other 2.
Already tried pushing the parts when playing music - still nothing 🙁
Reply 3 of 18, by shock__
Pictures aren't working for me.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 4 of 18, by root42
For me neither. Just use the forum upload function.
YouTube and Bonus
Reply 5 of 18, by borichka
Sorry for the mess. Hope you can see the photos now.
Please let me know what do you think.
Reply 6 of 18, by shock__
C67/C68 look like they might have been bent in the past. Check if they're still working correctly. C65 looks like it may have been battered in the past in the photo (which may not be the case ... hard to judge).
Otherwise the board looks fine to me.
[Z?]
Reply 7 of 18, by Salient
I once had a GUS with only one channel working. Turned out to be a malfuctioning TDA chip (U28). Once replaced it worked perfectly again.
This might be the case here too.
Reply 8 of 18, by borichka
I will check, thank you!
Reply 9 of 18, by borichka
If TDA isn't working, I should still have sound from line-out, non amplified?
Reply 10 of 18, by borichka
Tested all resisters - R70 is shortened, or is it normal?
Reply 12 of 18, by 640K!enough
At the very least, U2, U4, U5 and U8 look like they are not very well seated in their sockets. It may just be the picture, but some of the resistors near the GF1 look like they have been abused or had over-heated at one time. It might be worth looking into that first.
Reply 13 of 18, by borichka
Tiido wrote:
R70 is 4.7ohms so it will make a tester beep.
Good catch!
Reply 14 of 18, by borichka
Looks like I found one shortened resister, the bottom one. It should be 2.2K right?
However when Joystick is disabled with jumper, I read 235 Omh.
Reply 15 of 18, by borichka
Still can't make it work 🙁 Where can I find a replacement GF1 chip to try? How do I remove this chip from a deep socket to clean the contacts?
Reply 16 of 18, by cyclone3d
C42 is missing. Looks like somebody cut it off instead of unsoldering it.
Edit: Looking at other pictures of the 2.4 revision, it looks like there was never anything there... strange that your has snipped leads.
As for pulling the GF1 chip, you will need a PLCC chip puller to do it properly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 17 of 18, by borichka
I understand that C42 has been removed in the factory on all cards after manufacturing.
For the tool you mean something like the one below?
