First post, by appiah4
- l33t++
Running DosBOX-SVN, I can't seem to get any sound when using the MT-32 option. I am using the latest x64 version of MUNT on Windows 10 x64. Other games seem to work fine. Intelligent Mode is enabled in the config. Other games seem to work just fine with MUNT, so what could I be missing?
SB emulation also crapped out because it was apparently searching for an SB at IRQ5 by default so I had to add the SB2207 switch to the batch file.. Maybe I need to do something similar for the MIDI port etc?
