First post, by Mezmaron
This is the output of my old Rage Fury Pro AGP card. I've cleaned the contacts on it and everything else on the card to no avail:
1.99 MiB
Can anything be done with it, or is it a bad chip and pretty much beyond hope?
Reply 1 of 2, by canthearu
I think you press F7A03 to save and exit (looking for that key on my keyboard still)
Not sure if there is any particular reason to spend too much time on this card, unless you can see something obvious damaged.
