SS7 motherboard not working
Reply 20 of 24, by rasz_pl
again
>the only thing you should measure is drain-source junction
while in circuit, powered down, in diode multimeter mode, both directions
low resistance gate-source can mean blown LX1682, would result in same symptoms, testing will require desoldering to check
Reply 21 of 24, by PcBytes
rasz_pl wrote:
again >the only thing you should measure is drain-source junction while in circuit, powered down, in diode multimeter mode, bot […]
again
Here's a photo of what I mean. Explanation on the bottom of the picture.
    1.35 MiB
Reply 22 of 24, by rasz_pl
your pinout is wrong, your conclusions are wrong, pin 1 is gate
again
>again
Reply 23 of 24, by PcBytes
I get infinite resistance on all FETs when I do that.
Reply 24 of 24, by holoprox
so? what are we doing now for our beloved boards?
K6BV3+/66 REV:B1 here with AMD K6-2/450AHX - gets hot (very hot indeed near it's limit of 65 C) daws 43-45watts from the wall socket (CPU is up to 28W)
tested the board with AMD K6-2/500AFX (must be 20watts but also draws 45w or even more)
recapped 12 1000uF/6.3V caps - same sh...
no beeps, test card shows no 3.3 in PCI (but someone wrote that is to be expected) shows no activity only ----
dumped my bios with TL866-II Plus - seems good (socket seemed veeery dusty, cleaned it using contact spray)
sometimes test card behaves strange - reset glows all the time
100+ retro computers on board!
50+ flightsticks!
