First post, by rafik73
Greetings
I am new here, so welcome.
I want to use Dosbox to run an old program under DOS secured with an LPT key (the key is Dallas Semiconductor). The software manufacturer recommends some settings in the configuration files, namely:
AUTOEXEC.BAT FILE EXAMPLE FOR VIK PROGRAMS
FOR WINDOWS 95 OPERATIVE SYSTEM'S COMPUTER
@ECHO OFF
C:\WINDOWS\SMARTDRV.EXE 1024 /V
PATH=C:\WINDOWS\COMMAND;C:\WINDOWS;C:\APM
SET TEMP=C:\WINDOWS\COMMAND
SET :HOME:=C:\APM
PROMPT $P$G
C:\MOUSE\MOUSE
C:\WINDOWS\COMMAND\KEYB IT,,C:\WINDOWS\COMMAND\KEYBOARD.SYS /E
C:\WINDOWS\COMMAND\DOSKEY.COM
MODE CON: DELAY=1 RATE=32
CONFIG.SYS FILE EXAMPLE FOR VIK PROGRAMS
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE RAM
BUFFERS=30,0
FILES=30
DOS=UMB
LASTDRIVE=Z
FCBS=16,0
DOS=HIGH
DEVICE=C:\WINDOWS\COMMAND\ANSI.SYS
COUNTRY=039,,C:\WINDOWS\COMMAND\COUNTRY.SYS
STACKS=9,256
FOR MS-DOS 6.22 OPERATIVE SYSTEM'S COMPUTER
@ECHO OFF
C:\DOS\SMARTDRV.EXE 1024 /V
PATH=C:\DOS;C:\APM
SET TEMP=C:\DOS
SET :HOME:=C:\APM
PROMPT $P$G
C:\MOUSE\MOUSE
C:\DOS\KEYB IT,,C:\DOS\KEYBOARD.SYS /E
C:\DOS\DOSKEY.COM
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=30,0
FILES=30
DOS=UMB
LASTDRIVE=Z
FCBS=16,0
DOS=HIGH
DEVICE=C:\DOS\ANSI.SYS
COUNTRY=039,,C:\DOS\COUNTRY.SYS
STACKS=9,256
How do you apply these settings in DOSBOX?
