First post, by elianda
- l33t
Hello,
I was testing a few Adaptec ISA SCSI cards and noticed that my Adaptec 1542B does not seem to work with CD-ROMs.
The card is an Adaptec 1542B with Adaptec AT BIOS 3.10 with max. HDD size of 1 GB.
When the BIOS scans the bus I see the drive initialize, but it does not shows on screen. It just waits and continues after a while with no device found.
I thought I can simply load ASPI4DOS 3.36S but it always say installation failed. As if the driver is incompatible with this card.
However when I run SCSIFRMT which is actually for formatting HDDs it scans the bus and lists the attached CD-ROM fine.
Does anyone knows something regarding this issue?
Is the 3.10 BIOS not capable of CDROMs?
Is the BIOS too old to work with ASPI4DOS or do I need an old version of ASPI4DOS?
As ID 0,1,2 is reserved for bootable devices the CD-ROM is set to ID3 and terminates the bus. It works also fine with other SCSI controllers in the same setup.
Youtube Channel
