Reply 20 of 24, by superfury
Just found out something strange booting the Bochs' openBSD floppy disk. It executes a ATAPI reset command, then a ATAPI IDENTIFY, then a ATAPI PACKET command, sends one word, then says "wdc1:0:0: device timeout, c_bcount=0, c_skip=0"?
Edit: It seems to be executing the instruction F2666F, which is a REPNZ OUTSW? But the REPNZ is invalidated, thus not active? What should happen in this case?
Edit: Just changed the REPNZ instruction to actually act as a normal REP for INS and OUTS instructions, instead of invalidating the REPNZ prefix altogether. That should fix that bug.
UniPCemu Git repository
