First post, by kalm_traveler
- Member
Hello folks - I have been lurking here for a few weeks as I have recently decided to build the 'ultimate' form of my first all-new PC from late 2000 (though I may end up cheating as I got a little Buy It Now happy on ebay and ended up with 4 graphics cards, 2 CPUs, 2 sound cards, etc).
The parts all seem to be in good working order, I am trying to use the following for now:
Asus TUSL-2C socket370 motherboard (with the onboard sound disabled of course)
Pentium III S 1.13ghz (the fastest I could have purchased back in '00, though I'm cheating with a Tualatin 512kb version)
512mb PC133 SDRAM (256mb, 128mb, 128mb sticks)
Elsa Gloria III (Nvidia Quadro 2 Pro) graphics card
Creative Labs Sound Blaster Audigy 2 ZS sound card (I know this is cheating, but the 2 ZS is not drastically different from the original... just better)
Intel 10/100/1000 NIC
Star Tech 7 port USB 2.0 card
Sil3114 4 port SATA RAID card (first problem)
Crucial 250gb SATA SSD
Asus SATA DVD RW
EVGA 550 B3 550w PSU (second problem)
The goal here is to set it up to dual boot Windows ME and Windows 2000, but I've been road blocked for the last 2 days and can't figure out how to pass these...
problem 1 is that the system will not boot at all with the EVGA PSU. It's brand new, works fine on other/newer machines - and it did boot this one once or twice but now when the 20-pin (I had to cut off the end 4 pins of the 24 pin connector since the motherboard has the old 20-pin plug) is connected the MB green standby light is on but pressing the power button only just barely bumps the fans but no booting up happens.
I tried using a spare EVGA 450w PSU and the behavior is the same. However, I happened to have an ancient (era appropriate) PSU laying around and that thing boots it up just fine every time, though it lacks any SATA power connectors so for now I'm using it to power the 20-pin ATX connector, and one of the EVGA PSU's to run everything else by jumping its ATX connector.
The only functional difference I've found is that the EVGA PSU's have an empty pin that is -5v on the old PSU, and that same -5v is noted in the Asus TUSL-2C manual. As far as I understand that was only used by ISA devices so I am not sure how or why that would affect the system booting (and as mentioned it HAS booted a few times from the EVGA PSUs, just very rarely). Is there a brand that would be more likely to work - or something I may need to do to get these EVGA units working properly with the board?
and on to problem 2 - the Sil3114 SATA RAID controller... I've read a number of threads here about updating the BIOS which I have done - to the base (non-raid) 550 version (latest on their website). However, the system won't even try to boot from anything in the optical drive and when trying to launch the Windows ME floppy boot disk installer nothing can detect a CD-ROM drive. I tried adding in that gcdrom.sys file (and its appropriate entries in the boot disk's config.sys), as well as an AHCI driver from HP) to no avail.
I've also tried using a VIA chipset SATA card and the behavior is identical. Looking at possibly trying a Sil3512 card if that might help, but this 3114 card supposedly supports ATAPI drives already so I'm not sure what is missing.
Do you guys have any suggestions on anything I'm overlooking or may want to try?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 10980XE, 64gb DDR4, 2x Titan RTX | i9 9900KS, 32gb DDR4, RTX 2080 Ti | '19 Razer Blade Pro
