First post, by Kenichi-san
Hello guys,
I'm trying to configure the Autoexec section of Dosbox. I downloaded DOSBOX for Windows and I added these lines :
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
MOUNT C C:\DOSGAMES\
C:
I saved and ran Dosbox.exe, it worked !
I'm doing the same thing for `Dosbox in Fedora 30`, configuring the file `dosbox-0.74.conf` located in `/usr/share/dosbox/translations/fr`.
But when I run it, it doesn't work.
Here is a screenshot :
It worked for Windows...
I tried to put these lines on each `dosbox-0.74.conf` located in each translation folder, but still not working.
I think that the application doesn't run this configuration file, it seems to be another file, but which one?
I've made a search of `dosbox` and these were the only files existing.
