PNY Geforce GTX 650 2gb - wimpy card?
Reply 20 of 21, by buckeye
agent_x007 wrote:
You can't run Crysis on Very High without DX10 OS (or hacked config files). […]
You need high clocked Sandy/Ivy Bridge to get over 60FPS on minimum FPS.
I played/completed Crysis with ~30FPS no problem.
It's just as well, prices for a 750ti are too high (for me anyways) so probably going back to square one and stick the 7950GT back
in and fix the games that were broken by the GF650. It was fun to experiment anyways!
Reply 21 of 21, by buckeye
bakemono wrote:
GTX 650 seems like a pretty good card to me, I bet you need a faster CPU to hit 60fps in Crysis. Although I thought Crysis only went to "high" settings in XP, how did you run it on "very high" ?
I stand corrected, "very high" not available for Dx9. Anyways, tested some more:
High setting 1280x1024 No AA, V-sync, 32bit full screen (3) loops = (54.91) avg. fps
High setting 1024x768 same as above = (69.31) avg. fps
Also add another game that's screwed up with this card - Star Wars Republic Commando, textures not right.
