First post, by eL_PuSHeR
- l33t++
I am finally fed up with my AC'97 (ALC650) failing a lot on games.
Tested both nVIDIA and Realtek drivers. No difference.
What I need is...
- Card must be PCI.
- Must be low-budget (I don't want to invest too much on my current setup).
- Must be good enough to be worth replacing for the ALC650
- I don't need any fancy features. I just use 2 speakers and headphones.
- Must be compatible with my nFORCE2 chipset.
I have been looking a bit and there are PCI cards as low as 29€ (I have even seen some of them at 6€). I want something in the middle-range but not too expensive. Up to 50-60€ would be okay.
Thanks in advance.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
