First post, by RiP
- Member
Does anyone know the model of this 386 motherboard? 😕
Biostar most likely. The label with the model number was removed, it resisted in the lower left corner above "Ver:1.0".
wrote:
Thank you very much. Sadly, the board didn't work 😢
Well, never give up on it.
No beep, no video...
Actually, 2/3 of motherboards I take are dead =/
I really wanna get this board to work instead:
Need to identify this motherboard
You should never give up that fast. You dont even know what is wrong. Buy a ISA POST card from China (3€), will give you much more data. A TL866 for checking and programming ROMs is also useful.
wrote:You should never give up that fast. You dont even know what is wrong. Buy a ISA POST card from China (3€), will give you much more data. A TL866 for checking and programming ROMs is also useful.
I'm not familiar with debugger cards. Which model is better?
Only those models I sent are available here.
wrote:Only those models I sent are available here.
Last one. Only one which can detect voltages.
