Quake 2 on Pentium MMX + Voodoo 2 8MB
First post, by rcarkk
Hi guys. Yesterday, i saw a video on Quake 2, running on a Pentium MMX 233Mhz and Voodoo 2 8MB with sound enabled with a Soubblaster PCI128. The score achieved was 40.6fps on demo1.dm2 at 640x480 and 8 bit textures off.
My question is. I´m not being able to emulate those framerates. My system only scores 31.3fps with the same MMX 233, V2 8MB and Live 5.1 Digital. The board is an Epox P55 VP3. If i disable the sound, i can go up to 40.2fps at 640x480 with 8bit textures off.
The strange part is that the Phils Voodoo 2 scaling test ranging from 100Mhz to 1400Mhz scores 40.1fps with no sound card and the Pentium MMX 233Mhz. Can anyone confim the results on similar machines and sound enabled?
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 1 of 20, by mothergoose729
The performance you get on each board and with each hardware configuration can definitely vary by that much. The further back in time you go, hardware wise, the more that is the case.
The live 5.1 is probably the culprit here, as some sound cards have much higher CPU requirements than others. But the memory timings, the board, and the chip set can also have an impact as well.
Reply 2 of 20, by lost77
The chipset and ram timings can make a lot of difference. Also other settings like sound quality (11Khz, 22Khz), gl_ztrick, vsync on/off, overclocking.
Reply 3 of 20, by rcarkk
The timmings are 2-3-2-2. Can anyone here run Quake 2 at 512x384 with no sound on demo1.dm2? I would like to see pure CPU performance on software renderer. Just to see if the system is underperforming. I would apreciate a lot.
The K6-III build
Reply 4 of 20, by The Serpent Rider
Pentium MMX 233 / 430TX / 64 MB RAM CL2 / Voodoo 3 PCI 3000 / 3dfx MiniGL / No sound - 46 fps.
Voodoo 2 should give almost the same result in 640x480, because they both are bottlenecked by a Pentium CPU.
Reply 6 of 20, by The Serpent Rider
Doom is a horrible benchmark for a Pentium class CPUs. There's a performance brick wall around 80 fps in many cases, due to how Doom renders the graphics. Quake 1.06 timedemo is much better.
Reply 7 of 20, by rcarkk
I can try using the V3 2000PCI and OC to 3000 levels. That should give acurate comparison.
The K6-III build
Reply 8 of 20, by The Serpent Rider
Just run DOS Quake without sound. Reference performance is around 48-52 fps on demo1 (430HX-430TX chipsets). That said, your board on a VIA VP3 chipset most likely will require Memory Interleave enabler patch. Just google it.
Reply 9 of 20, by swaaye
Are you using WDM or VXD drivers for the Live? VXD is usually the way to go for Win9x and should save you some CPU time. WDM was pretty raw and quirky back then.
Reply 10 of 20, by rcarkk
I run Quake at what resolution? 320x200 or 320x240?
The K6-III build
Reply 11 of 20, by rcarkk
I have used the drivers provided on the Live 5.1 CD. Are they VXD? How do i know that?
The K6-III build
Reply 12 of 20, by rcarkk
mothergoose729 wrote:
Try these set of benchmarks for performance reference points:
https://docs.google.com/spreadsheets/d/1uKhCI … #gid=1719797471
In Doom, a pentium MMX 233 scores between 82-96 fps, or between 150-176 in Speedsys.
Thank you for that link.
The K6-III build
Reply 13 of 20, by The Serpent Rider
Default resolution is 320x200. HUD2 - health, armor, ammo + weapons and keys bar.
Reply 14 of 20, by rcarkk
The VP3 chipset and MMX 233 is scoring 47fps on DOSQuake. Not to bad, but not impressive either.
The K6-III build
Reply 15 of 20, by rcarkk
They seem to be WDM acording to dxdiag...
The K6-III build
Reply 17 of 20, by The Serpent Rider
That's normal for VIA chipsets. They weren't top performers on 66mhz FSB.
Reply 18 of 20, by Windows9566
hows the intel 430HX chipset compared to the VIA chipset?
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 19 of 20, by amadeus777999
You may run Doom without the refresh option which eliminates most of the measure that depends on the bus and gfx hardware.
