First post, by Anders-
null
Måttfull och balanserad.
Reply 1 of 4, by keenmaster486
Extract all the files from the images to a folder called WIN311 on the directory you have mounted as C:\ in DOSBox. Then run SETUP from there.
World's foremost 486 enjoyer.
Reply 4 of 4, by JudgeMonroe
keenmaster486 wrote:
You have some kind of issue. There should be SETUP.EXE in the folder with all the install files.
He's probably using a localized version, which does have an INSTALL.EXE instead of SETUP.EXE.
