First post, by T-Squared
- Member
The Win98SE rig I built is acting a bit strange... It doesn't work quite correctly when it starts up. I've installed all of the Win98 updates using the Auto-Patcher you can find on the internet, just to let you know. The problem I have is that the system will not enter the GUI interface unless it's being bootlogged (i.e. the booting sequence is logged in a file). Kind of an "observer effect", if you will. I don't know what's wrong, or where the problem is, but while it's inconvenient, it's not major.
